Thread Closed
truss element
Share Thread
Mar26-10, 11:55 PM   #1
truss element
in finite element analysis there is no poisson ratio for LINK ELEMENT (truss structure)
just explain ?
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Mar27-10, 01:54 AM   #2
Because shear forces are ignored in the basic analysis of plane truss elements. Structural models that take into account shear stress (Timoshenko beam theory) will give results involving the shear modulus, which is a function of Poisson's ratio.
Mar27-10, 06:35 PM   #3
Recognitions:
Just as an aside LINK elements are typically not used for trusses. For modeling a truss, you would really want to use a BEAM element. You use LINK when either trying to simply tie together a couple of different parts/regions or need tension/compression only spars.
Thread Closed
Similar discussions for: truss element
Thread Forum Replies
If a is an element of R can you assume -a is an element of R? Calculus & Beyond Homework 6
ANSYS command problem re element death/element table postprocessing Math & Science Software 1
beam element vs. Finite element? Mechanical Engineering 3
differences between natural element and built element? Biology, Chemistry & Other Homework 4
zero element/unit element Calculus & Beyond Homework 2
