Matrices of simple face and cubic centered cubic lattice
  • Context: Graduate
  • Thread starter Thread starter Petar Mali
    Cubic Lattice Matrices
This discussion focuses on the matrices representing simple cubic, volume-centered cubic, and face-centered cubic lattices. The simple cubic lattice is defined by the matrix S, which is a diagonal matrix with side length 'a'. The volume-centered cubic lattice is represented by matrix I, which includes negative and positive half-lengths of 'a', while the face-centered cubic lattice is represented by matrix F, which positions atoms at the face centers and corners of the cube. The discussion emphasizes the geometric interpretation of these matrices in defining lattice points through integer combinations of lattice vectors.
  • Understanding of lattice structures in crystallography
  • Familiarity with matrix representation of geometric transformations
  • Knowledge of cubic lattice types: simple, body-centered, and face-centered
  • Basic concepts of vector addition in three-dimensional space
  • Study the mathematical properties of cubic lattices in crystallography
  • Explore the derivation of lattice vectors for different crystal structures
  • Learn about the applications of lattice matrices in solid-state physics
  • Investigate the relationship between lattice structures and material properties
Students and researchers in materials science, crystallography, and solid-state physics who are interested in understanding the mathematical foundations of crystal lattice structures.
Petar Mali
[tex]S=<br /> \begin{bmatrix} a & 0 & 0 \\ 0 & a & 0 \\ 0 & 0 & a \end{bmatrix}[/tex]
for simple cubic
[tex]I=<br /> \begin{bmatrix} -\frac{a}{2} & \frac{a}{2} & \frac{a}{2} \\ \frac{a}{2} & -\frac{a}{2} & \frac{a}{2} \\ \frac{a}{2} & \frac{a}{2} & -\frac{a}{2} \end{bmatrix}[/tex]
for volume centered cubic
[tex]F=<br /> \begin{bmatrix} 0 & \frac{a}{2} & \frac{a}{2} \\ \frac{a}{2} & 0 & \frac{a}{2} \\ \frac{a}{2} & \frac{a}{2} & 0 \end{bmatrix}[/tex]
for face centered cubic
I don't see any logic for this matrices? How can I get this? I can axcept that simple is P because minimum distance between neighbors is [tex]a[/tex]. But But what with the other two matrices?
How are these matrices defined?
Those matrices have the lattice vectors as rows (or columns, since they are symmetric). If you have a cube with side length a and one corner at the origin, then integer combinations of those vectors give you the lattice points. I'm not sure what your question is. Look at FCC. You have one atom at each corner, so points like (a,0,0) and (0,a,0), etc. Then at the center of each face, so points like (a/2,a/2,0) and (a/2,0,a/2). Those points come from adding those vectors together.
  • · Replies 22 ·
  • · Replies 16 ·
