Using integrals to prove volume of a pyramid
The discussion focuses on using integrals to derive the volume of a pyramid, specifically addressing the setup of limits for integration. The user simplifies the problem to one quarter of the pyramid, defining variables c as half the base and h as the height. The integration process involves iterating through y, z, and x, ultimately leading to a formula that does not match the expected volume of a pyramid. Participants identify errors in the integration steps, particularly in the final term, suggesting that correcting the second term to b² will yield the correct volume.
  • Understanding of triple integrals in calculus
  • Familiarity with the geometric properties of pyramids
  • Knowledge of setting limits for integrals
  • Proficiency in LaTeX for mathematical notation
  • Review the derivation of the volume formula for a pyramid
  • Practice setting up limits for triple integrals
  • Learn to use LaTeX for mathematical expressions
  • Explore common mistakes in integral calculus
Students and educators in mathematics, particularly those studying calculus and geometry, as well as anyone interested in understanding the application of integrals to geometric volume calculations.
TromboneNerd
the first question i have is if i set it up the iteration right. The I've simplified to one quarter of the pyramid, so the value c is actually 1/2 the base of the whole pyramid. and h is the height of the pyramid. (the pinnacle of the pyramid is along the z axis)
[tex]0\leq z\leq -\frac{h}{c}x+h[/tex]
[tex]0\leq y\leq -\frac{c}{h}z+c[/tex]
[tex]0\leq x\leq c[/tex]
If all that is correct, then ill show my integration work and you can tell me where i went wrong. I don't know how to place lower and upper limits on integrals using Latex, so just use the limits from above.
[tex]V=4\int \int \int dydxdz[/tex]
in respect to y
[tex]=4\int \int (-\frac{c}{h} z+c)dzdx[/tex]
in respect to z
[tex]=4\int [-\frac{c}{2h} (-/frac{h}{c} x+h)^{2} +c(-\frac{h}{c} x+h)]dx[/tex]
finally in respect to x
[tex]=4(-\frac{c^{2} h}{6} +ch)[/tex]
[tex]=-\frac{2c^{2} h}{3} +ch)[/tex]
substitute in .5b for c
[tex]=-\frac{b^{2} h}{6} +\frac{bh}{2}[/tex]
this is obviously not anything close to the formula for the volume of a pyramid, and is completely non sensical. according to this, only very small values of b and h will produce a positive volume. where did i go wrong? I skipped quite a few steps for the sake of typing space, so if your not sure where i got this or that from ill show you the more detailed work where the problem might lie.
I think you made a mistake with the last integral
Yep, you made a mistake
actually if the second term is b^2, you get the answer you need
  • · Replies 105 ·
13K
