What is the Resistance of R1 in a Dual Range DC Milliammeter?
  • Thread starter Thread starter thereddevils
    Resistance
The discussion focuses on calculating the resistance of R1 in a dual range DC milliammeter setup. The moving coil meter has a resistance of 50 ohms and achieves full-scale deflection at 1.0 mA. When connected to terminals A and C, a current of 20 mA results in full-scale deflection, leading to the equations R1 + R2 = 50 ohms and 1(50) = 19R1 + R2. The user concludes that R1 cannot equal zero, indicating a need for further analysis of the circuit configuration.
  • Understanding of Ohm's Law and circuit analysis
  • Familiarity with moving coil meters and their specifications
  • Knowledge of series and parallel resistor configurations
  • Basic proficiency in setting up and solving equations in electrical engineering
  • Review the principles of shunt resistors in ammeter design
  • Study the calculation of equivalent resistance in series and parallel circuits
  • Explore the concept of full-scale deflection in analog meters
  • Investigate common pitfalls in circuit analysis and troubleshooting techniques
Electrical engineering students, hobbyists working with analog meters, and professionals involved in circuit design and analysis will benefit from this discussion.
thereddevils
The figure shows a dual range dc milliammeter which has a common negative terminal A and positive terminal B and C . The indiacator is a moving coil meter of resistance 50 ohm which gives full scale deflectino with a current of 1.0 mA . When connection ismade with the terminals A and C , a current of 20 mA gives full scale deflection . What is the resistance of R1 ?
when A and B are connected to a circuit , R1+R2=50 ohm
when A and C are connected to a circuit ,
1mA will flow through the resistor R2 , then to the meter while 19 mA will flow through resistor R1 .
and pd across meter = pd across shunt
1(50)=19R1+R2 ---1
R1+R2=50 ----2
and R1=0 ??
Cant be !
is there anything wrong with my work ?
  • · Replies 19 ·
  • · Replies 45 ·
