Which is Correct? (delta p) (delta x) >= hbar or hbar/2?
  • Context: Graduate
  • Thread starter Thread starter greatscott
The discussion revolves around the Heisenberg Uncertainty Principle (HUP) and the differing formulations regarding the relationship between the uncertainties in position and momentum, specifically whether the inequality should be expressed as (delta p)(delta x) ≥ hbar or (delta p)(delta x) ≥ hbar/2. The scope includes theoretical implications and mathematical derivations related to quantum mechanics.
  • Some participants note that the uncertainty principle is often presented as an order-of-magnitude estimate, suggesting that without precise definitions for the uncertainties, the interpretation may vary.
  • One participant argues that using standard deviations leads to the conclusion that the correct formulation is (delta p)(delta x) ≥ hbar/2.
  • Another participant references different textbooks that present the HUP in varying forms, indicating a lack of consensus on the correct expression.
  • A participant proposes a method to derive the uncertainty relation for a simple harmonic oscillator (SHO) in its ground state, suggesting that the product of the uncertainties results in hbar/2.
  • Further elaboration includes a mathematical derivation involving the virial theorem and standard deviations, leading to the conclusion that σ_x σ_p = hbar/2.
  • Another participant discusses the derivation of the uncertainty principle from the Schwarz inequality, emphasizing that the factor of 1/2 arises under specific conditions related to the wavefunction's properties.
Participants express differing views on the correct formulation of the uncertainty principle, with no consensus reached. Some support the hbar/2 formulation, while others reference the hbar formulation, indicating ongoing debate.
Participants highlight the importance of definitions for the uncertainties involved and the conditions under which the inequalities hold. The discussion includes various mathematical approaches and assumptions that may influence the interpretations presented.
greatscott
hbar or hbar/2??
Regarding the uncertainty principle, some books say
and others say
(delta p) (delta x) >= hbar/2.
Which is right? This matters because I get different results when I
let p x=hbar(or hbar/2), plug into the expression for energy, and
minimize it to get the ground state energy of the system.
Sigh... unless exact definitions are given for those deltas, the statement of the Uncertainty Principle should be taken as an order-of-magnitude estimate only. I believe that when one employs standard deviations, which is the correct way to go about it, the answer is hbar/2.
zefram is correct
Cohen-Tannoudji's "Quantum mechanics" writes the HUP as [tex]\Delta[/tex]x[tex]\Delta[/tex]p(>~)hbar
Hameka's "Quantum mechanics" as [tex]\Delta[/tex]x[tex]\Delta[/tex]p>hbar
There is a simple way to settle the issue. The inequality becomes equality for the SHO in its ground state. So if anyone wants to calculate the the standard deviations [itex]\sigma_x=\sqrt{ <x^2>-(<x>)^2}[/itex] and similar for p, then multiply them out, we have the answer. Actually it's easy:
[tex]<x>=<p>=0 \; so \; \sigma_x \sigma_p = \sqrt { <x^2> <p^2> }[/tex]
By the virial theorem:
[tex]\frac{<p^2>}{2m} = \frac{1}{2} k<x^2> = \frac{E_0}{2} = \frac{\hbar \omega(0+1/2)}{2}[/tex]
[tex]<p^2>=\frac{m \hbar \omega}{2}, <x^2>=\frac{\hbar \omega}{2k}[/tex]
[tex]\sigma_x \sigma_p = \frac{\hbar}{2} \sqrt {\frac{m \omega ^2}{k}} \; but \; \omega^2 = k/m[/tex]
Hence [tex]\sigma_x \sigma_p = \hbar /2[/tex] is the final answer. Note to self: learn Latex. It took me far longer to compose this than to actually solve the problem.
...is the final answer
That is how the HUP appears in Griffith's "Introduction to Quantum mechanics"
:smile: :smile: :smile:
Maybe not appearing in your derivation is the fact that the equality holds when the wavefunction has the same "shape" in postion and momentum variables. That is, when the Fourier transform of the wavefunction is analogous to the initial wavefunction : in the gaussian case, which applies to Harm. Oscill. you used.
Maybe I'll give a try to latex too... :wink: :-p
OK, the all story is simple : the Heisenberg undeterminacy principle simply follows from the Schwarz inequality. Let us see how. Consider a state [tex]\psi[/tex] and two observables [tex]\hat{A}[/tex] and [tex]\hat{B}[/tex].
Now the standard deviation is given by :
[tex] ( \Delta a )^2 = \langle \psi|(\hat{A} - \langle a\rangle )^2 |\psi\rangle = \langle (a - \langle a\rangle )^2 \rangle [/tex]
This seems natural. Why bother an overall factor at this stage ?
Let [tex]\hat{A'} = \hat{A} - \langle a\rangle[/tex]
Then [tex]( {\Delta}a )^2 = \langle\psi|\hat{A'}^2|\psi\rangle[/tex]
Likewise for [tex]\hat{B}[/tex] one gets
[tex]( {\Delta}b )^2 = \langle\psi|\hat{B'}^2|\psi\rangle[/tex]
Now the real argument : Schwarz inequality. I redemonstrate.
Consider the norm of the vector
[tex](\hat{A'} + i\lambda \hat{B'} )|\psi\rangle[/tex]
This vector has positive norm :
[tex] \langle\psi|(\hat{A'} - i\lambda \hat{B'} )(\hat{A'} + i\lambda \hat{B'} )|\psi\rangle\geq 0 [/tex]
From this follows simply :
[tex] (\Delta a)^2 + \lambda^2 (\Delta b)^2 + i \lambda \langle \psi |[\hat{A'},\hat{B'}]|\psi\rangle\geq 0 [/tex]
As you can see, a 2nd order polynomial in [tex]\lambda[/tex] which is always positive will lead to :
[tex] (\Delta a)(\Delta b) \geq \frac{1}{2}\langle \psi |[\hat{A},\hat{B}]|\psi\rangle [/tex]
and I did not bother about the primes, since the commutators are equal :
[tex] [\hat{A},\hat{B}]=[\hat{A'},\hat{B'}][/tex]
This is the general way of deriving the [tex]\frac{1}{2}[/tex] factor.
____________________________________________________________
Let me add the HO argument's origin : let us see how gaussian functions appear. The inequality becomes an equality iff the second order polynomial vanishes, that is when
[tex]\lambda = \lambda_0 = \frac{\hbar}{2(\Delta b)^2}=\frac{2(\Delta a)^2}{\hbar}[/tex]
in which case the vector has vanishing norm, so :
[tex][\hat{A}-\langle \hat{A}\rangle+i\lambda_0(\hat{B}-\langle \hat{B}\rangle)]|\psi\rangle = 0[/tex]
Therefore, the condition for the inequality to become an equality is that the vectors [tex][\hat{A}-\langle \hat{A}\rangle]|\psi\rangle = 0[/tex] and [tex][\hat{B}-\langle \hat{B}\rangle]|\psi\rangle = 0[/tex] be proportional to each other (linearly dependent).
Let us take [tex]\hat{A}=\hat{x}[/tex] (position) and
[tex]\hat{B}=\frac{\hbar}{i}\widehat{\frac{d}{dx}}[/tex]
We collect the equation :
[tex] \left[ x + \hbar\lambda_0\frac{d}{dx} -\langle \hat{A}\rangle - i \lambda_0 \langle \hat{B} \rangle \right] \psi(x)[/tex]
with [tex]\langle\hat{x}|\psi\rangle[/tex].
We furthermore eliminate mean values :
[tex] \psi(x) = e^{i\langle\hat{B}\rangle x/\hbar}\phi(x- {\langle \hat{A}\rangle} )[/tex]
in order to get :
[tex]\left[ x + \lambda_0\hbar\frac{d}{dx}\right]\phi(x)=0[/tex]
whose solution is :
[tex]\phi(x) = C e^{-x^2/2\lambda_0\hbar}[/tex]
C is an arbitrary compex constant.
Finally :
[tex]\psi(x) = \left[2\pi(\Delta x)^2\right]^{-\frac{1}{4}}e^{i\langle p\rangle x/\hbar}e{-\left[ \frac{x-\langle x\rangle}{2\Delta x} \right]^2}[/tex]
We note that the same lines can be carried out in the momentum representation, where one gets :
[tex]\bar\psi(p) = \left[2\pi(\Delta p)^2\right]^{-\frac{1}{4}}e^{i\langle x\rangle p/\hbar}e{-\left[ \frac{p-\langle p\rangle}{2\Delta p} \right]^2}[/tex]
credit : Jean-Louis Basdevant "Mecanique quantique, cours de l'X"
  • · Replies 0 ·
  • · Replies 19 ·
  • · Replies 73 ·
9K
