Simple Torque Problem: Find the Torque and Force Exerted by Triceps Muscles
  • Thread starter Thread starter putongren
    Torque
The discussion revolves around calculating the torque and force exerted by triceps muscles while accelerating a 3.6 kg ball at 7.0 m/s². The forearm length is 30 cm, and the calculations yield a torque of 0.756 Nm and a force of 25.2 N. The solution approach involves using the equations τ = Iα and τ = R x F, with the participant correctly applying the formulas. An alternative method suggested is to first calculate the force using F = ma before determining the torque. The calculations and methodology presented are confirmed to be correct.
putongren
There is no answer in the back of the textbook to the problem I did. I'm self-studying, so can someone check if my answer is correct.
The forearm accelerates a 3.6 kg ball at 7.0 m/s2 by means of the triceps muscle. The forearm is 30 cm long and is perpendicular triceps muscle. Calculate the torque and the force exerted by triceps muscles.
\tau = I\alpha
\tau = R x F
a = 7.0 (m/s2), m = 3.6 (kg), r = .03 (m)
\tau = I\alpha , \alpha = a/r, I = m*r2
= m*r2\alpha
= m*r*a
= 3.6*.03*7
\tau = .756
\tau = r * F
F = \tau/r
F = .756/.03
F = 25.2
Your answers are correct. Though you could have found the force (ma) first and then the torque (rF)
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
