How Do You Calculate the Moment of Inertia for a Sphere Using Shell Integration?
The discussion revolves around calculating the moment of inertia for a sphere using shell integration. The original poster attempts to derive the moment of inertia by decomposing the sphere into infinitesimal shells and integrating over them.
  • Mathematical reasoning, Assumption checking
  • Participants discuss the integration process and the substitution of mass elements. There are questions regarding the correct expression for density and the proper setup of the integral.
Some participants have pointed out potential errors in the original poster's approach, particularly concerning the replacement of the mass element under the integral. The conversation is ongoing, with attempts to clarify the integration steps and assumptions being made.
There is a mention of confusion regarding the expression for density and how it affects the integration process. The original poster also notes a formatting issue with symbols in their post.
Zamba
calculate the moment of inertia of a sphere of mass M and radius R by integrating over thin shells
Ishell=(2/3)mR2
this is what i have so far
the sphere is decomposed into infinitesimal shells with surface area 4[tex]\pi[/tex]r2
the mass of each shell is dm=[tex]\rho[/tex](4[tex]\pi[/tex]r2)dr
after expanding rho and canceling terms I get
dm=(3m/r)dr
I=[tex]\int[/tex](2/3)(dm)r2dr from 0 to R.
I=2mrdr from 0 to R
this gives me I=mr2
does anyone see what I did wrong?
PS. those "pi" are not supposed to be powers. sorry, I'm not sure how to change them
You did not replace dm with ρ(4πr2) under the integral sign. Instead, you integrated dm into m and then integrated over dr once more.
i'm sorry, i didn't write it all out
I=[tex]\int[/tex](2/3)dmr2 dr
from here I replaced dm with (3m/r)dr so i got
I=[tex]\int[/tex](2/3)(3m/r)r2 dr
then i got
I=[tex]\int[/tex]2mr dr from 0 to R
which gave me mr2
Zamba said:
... from here I replaced dm with (3m/r)dr...
And why is that correct? What expression did you use for the density?
  • · Replies 40 ·
  • · Replies 27 ·
  • · Replies 17 ·
