How can I calculate the theoretical spring constant using physical parameters?
The discussion revolves around calculating the theoretical spring constant of a spring using its physical parameters, as part of a lab requirement. Participants explore the relationship between these parameters and the spring constant, while also comparing theoretical calculations to experimental results.
  • Homework-related, Technical explanation
  • One participant seeks assistance in calculating the theoretical spring constant based on physical parameters, indicating they can handle experimental calculations.
  • Another participant suggests consulting a textbook that may contain relevant equations for spring design, implying that the inquiry may be homework-related.
  • A participant questions the meaning of "physical parameters," seeking clarification on what is being referred to.
  • Another participant proposes that physical parameters include size, shape, and material used for the spring.
The discussion does not reach a consensus on the definition of physical parameters or the specific equations needed for the calculation of the spring constant.
There is a lack of clarity regarding the specific physical parameters that should be considered in the calculation, and no equations or methods have been definitively established in the discussion.
drdizzard
I'm working on a lab and part of it requires the calculation of the theoretical spring constant of a spring based on its physical parameters and compare it to the spring constant calculated experimentally. I can calculate k using my experimental data fine, but I can't find anything on calculating it based on physical parameters. Any help would be appreciated.
What do you mean physical parameters?
Size, shape and material used?
14K
  • · Replies 25 ·
9K
  • · Replies 18 ·
