What is the magnitude of gravitational force between Earth and the Moon?
  • Thread starter Thread starter zelda1850
    Force Magnitude
The discussion revolves around the gravitational force between the Earth and the Moon, specifically focusing on the relationship between their masses and the forces they exert on each other according to Newton's laws of motion.
  • Participants explore the implications of Newton's third law regarding the gravitational forces between two bodies. There are attempts to clarify the concept of magnitude in relation to gravitational force and mass. Questions are raised about the correctness of applying gravitational equations and the interpretation of force in this context.
The discussion is active with participants questioning assumptions about gravitational force and clarifying the application of Newton's laws. Some guidance has been offered regarding the definitions of magnitude and the nature of forces, but there is no explicit consensus on the specific calculations or interpretations being discussed.
There is a mention of the educational level of the problem, indicating it may relate to GCSE or higher mechanics, which could impose certain constraints on the methods and reasoning expected in the discussion.
zelda1850
earth mass is approximately 81 times the mass of the moon. if Earth exerts a gravitational force of magnitude f on the moon, the magnitude of the gravitational force of the moon on Earth is
1) F
2) f/81
3) 9f
4) 81 F
i think the equation should be 81f
is it right that gravity*mass gives magnitude?
If this is GSCE or higher level mechanics you should be using Newton's Laws of motion.
What does Newton's third law say?
You're thinking of gravitational force = mass*g, where g is the acceleration due to gravity at that point (or, equivalently, the strength of the gravitational field). Most often used near the surface of the earth, where g is known to be about 9.8 m/s^2.
Hint: That's not needed to answer this question.
new third law says The force exerted by Object A on Object B is equal in magnitude but the opposite direction so the magnitude should be the same as the one on the moon?
Exactly.
I think you are misunderstanding the term 'magnitude'.
If you know the differences between vector and scalar quantities then you should know that vector quantities have both magnitude and direction, whereas scalar applies only magnitude.
Displacement and Distance are examples of the different values using the same units of measurement.
For example;
Traveling around your house, from the front door clockwise and back to the front door in a circular path would give you a distance traveled of [tex]2 \pi r[/tex] where r is the distance from your starting point to the centre of your path of motion.
Your displacement in this situation would be 0, as you have made no overall net movement.
Another way of putting it is *how much of an impact has this journey had on your initial state*, so you see your magnitude of travel is obvious due to your legs getting tired, however if an observer where watching you at the start, closed their eyes and opened them once you had finished your cycle they would have no idea you had moved at all!
Hope that helps a little =]
  • · Replies 18 ·
