Thread Closed
Stream function for double sink / source flow
Share Thread Thread Tools
Apr5-10, 10:06 AM   #1
Consider a source/sink in the origin of a coordinate system with a strength equal to 2m and two sources/sinks, each with a strength of −m, i.e. with a opposite sign with respect to the source/sink in the origin. The two sources/sinks are positioned along the x-axis at x = δx and x = −δx, respectively. Consider the limit for δx → 0 under the condition that
[tex]\lim_{\delta x \rightarrow 0} \delta x^2 m = \mu_2[/tex]
with [tex]\mu_2[/tex] finite. Consider this problem in three dimensions and sketch the resulting streamline patterns. Is there a closed streamline, which does not pass through the origin.
2. Relevant equations
The potential [tex]\Phi_e[/tex] for a single source/sink of strength m in 3D is:
[tex]\Phi_e=-\frac{m}{4\pi r}[/tex]
[tex]\bar{u}_e=\nabla\Phi_e=-\frac{m \bar{r}}{4\pi r^3}[/tex]
with [tex]\bar{r}=\bar{x}-\bar{x}_0 [/tex] where x = (x, y, z) and [tex] r = |\bar{x}-\bar{x_0}| = \sqrt{x^2 + y^2 + z^2}[/tex]
3. The attempt at a solution
Since the poisson equation which leads to the potential solution above is linear, I can add the 2 sinks and 1 source together to get 1 potential:
[tex]\Phi_e=-\frac{m}{4 \pi}\left(\frac{-1}{|\bar{x}-\delta\bar{x}|}+\frac{2}{|\bar{x}|}+\frac{-1}{|\bar{x}+\delta\bar{x}|}\right)[/tex]
I have to take the limit to 0 for δx and I want to introduce [tex]\mu_2[/tex] so I take:
[tex]\Phi_e=\lim_{\delta x \rightarrow 0} -\frac{m \delta x^2}{4 \pi}\frac{1}{\delta x^2}\left(\frac{-1}{|\bar{x}-\delta\bar{x}|}+\frac{2}{|\bar{x}|}+\frac{-1}{|\bar{x}+\delta\bar{x}|}\right)[/tex]
From this point on I'm highly unsure about my method.
Taking the limit it follows that [tex]\lim_{\delta x \rightarrow 0} \delta x^2 m = \mu_2[/tex] and [tex]\frac{1}{\delta x^2}\left(\frac{-1}{|\bar{x}-\delta\bar{x}|}+\frac{2}{|\bar{x}|}+\frac{-1}{|\bar{x}+\delta\bar{x}|}\right)=\frac{\partial}{\partial x^2}\left(\frac{3}{|\bar{x}|}\right)[/tex]
So my potential becomes:
[tex]\Phi_e=\frac{\mu_2}{4\pi}\frac{\partial}{\partial x^2}\left(\frac{3}{|\bar{x}|}\right)[/tex]
From here I could proceed to calculate the velocity, but honestly I don't trust my answer enough to take the effort so I first wanted to ask whether anybody could run through my calculation and comment on any mistakes/errors!
Thanks in advance!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Apr5-10, 06:23 PM   #2
I do not know what streamline patterns are, but I can help with the math some. I have no idea where you came up with the solution you got. But I played with it some and got a nice solution for the potential in the end, so I can only guess I did it right.
You will first want to write out [tex]|\vec{x}-\vec{\delta x}|[/tex] out in square roots.
Then you are going to want to expand your potential in a taylor series since you know [tex]\delta x[/tex] is small.
I also recommend expanding it out to 2nd order since you know you want [tex]\delta x^2[/tex] (because they give you a limit for it). That, and you will see something happen to the first order term.
Apr6-10, 12:32 AM   #3
Ok, I know that the source/sink are positioned on the x-axis so [tex]\delta\vec{x}=\delta x[/tex]. Then I get:
[tex]
|\vec{x}-\vec{\delta x}|=\sqrt{x^2+y^2+z^2+\delta x^2-2x\delta x}
[/tex]
and
[tex]
|\vec{x}+\vec{\delta x}|=\sqrt{x^2+y^2+z^2+\delta x^2+2x\delta x}
[/tex]
Taylor expanding the [tex]\frac{-1}{|\vec{x}+\vec{\delta x}|}[/tex] and [tex]\frac{-1}{|\vec{x}-\vec{\delta x}|}[/tex] terms yields:
[tex]
\frac{-1}{|\vec{x}-\vec{\delta x}|}=\frac{-1}{\sqrt{x^2+y^2+z^2}}-\frac{x}{(x^2+y^2+z^2)^{3/2}}\delta x+0.5\left(\frac{1}{(x^2+y^2+z^2)^{3/2}}-\frac{3x^2}{(x^2+y^2+z^2)^{5/2}}\right)\delta x^2
[/tex]
and
[tex]
\frac{-1}{|\vec{x}+\vec{\delta x}|}=\frac{-1}{\sqrt{x^2+y^2+z^2}}+\frac{x}{(x^2+y^2+z^2)^{3/2}}\delta x+0.5\left(\frac{1}{(x^2+y^2+z^2)^{3/2}}-\frac{3x^2}{(x^2+y^2+z^2)^{5/2}}\right)\delta x^2
[/tex]
So the [tex]\delta x[/tex] term drops out of the potential and the 0-order terms cancel out against the [tex]\frac{2}{|\vec{x}|}[/tex] term so I get:
[tex]
\Phi_e=\frac{m\delta x^2}{4\pi}\left[\frac{1}{(x^2+y^2+z^2)^{3/2}}-\frac{3x^2}{(x^2+y^2+z^2)^{5/2}}\right]
[/tex]
Taking the limit then turns [tex]m\delta x^2[/tex] into [tex]\mu_2[/tex].
The problem I have with this equation is that I expect a derivative to pop up somewhere, because that's how the solution for a 'normal' sink/source doublet(single source, single sink with infinitesimally small distance to each other) is. Take a look at this: dipole flows
Apr6-10, 08:50 AM   #4
That last answer looks like the right answer except you lost a negative sign somewhere. Also thanks for the link, I know what you want now. You need to use the trick:
[tex]\frac{\partial^2 f(x,y,z)}{\partial x^2}=\lim_{h\to 0}\frac{f(x-h,y,z)-2f(x,y,z)+f(x+h,y,z)}{h^2}[/tex]
Just treat your:
[tex]f(x,y,z)=\frac{1}{|\vec{x}|}=\frac{1}{\sqrt{x^2+y^2+z^2}}[/tex]
That will give you a very similar expression to what you had originally, except you were originally off by a factor. Hope this helps. It will also give you the same answer you got in the last post (besides a negative sign) if you take the derivatives of your expression, just to check your work.
Apr6-10, 11:16 AM   #5
Then I get:
[tex]
\Phi_e=\frac{\mu_2}{4\pi}\frac{\partial^2}{\partial x^2}\left(\frac{1}{|\bar{x}|}\right)=\frac{\mu_2}{4\pi}\frac{\partial^2 }{\partial x^2}\left(\frac{1}{\sqrt{x^2+y^2+z^2}}\right)
[/tex]
Solving the differential part yields for my potential:
[tex]
\Phi_e=-\frac{\mu_2}{4\pi}\left[\frac{1}{(x^2+y^2+z^2)^{3/2}}-\frac{3x^2}{(x^2+y^2+z^2)^{5/2}}\right]
[/tex]
Just like you said I would. Thanks! That was really helpful!!
Apr6-10, 11:35 AM   #6
No problem. Hah, that method was easier than a taylor expansion anyways. Didn't know about that method until you showed me, so we both learned something.
Thread Closed
Thread Tools
Similar Threads for: Stream function for double sink / source flow
Thread Forum Replies
What is magnetic pole? What is sink/source? Classical Physics 6
fluid mechanics: source and sink flows Mechanical Engineering 6
Vertical flow rate of water stream under gravitation General Physics 7
Earth as an energy source & sink General Physics 1
