Can the Disc Method Be Applied When Rotating Around y=x?
  • Context: Undergrad
  • Thread starter Thread starter flyers
    Disc Method Volume
The discussion centers on the application of the disc method for calculating volumes of revolution when rotating the area between the functions y=x² and y=x around the line y=x. The key challenge identified is the need to transform the equations into standard form, as traditional methods typically apply to rotations around the x-axis or y-axis. The radius of the disk is determined by the line perpendicular to the axis of rotation, complicating the integral setup, which requires a combination of differentials rather than standard "dx" or "dy". Transforming the coordinate system is recommended as the most effective approach for solving this problem.
  • Understanding of the disc method for volume calculation
  • Familiarity with functions and their graphs, specifically y=x² and y=x
  • Knowledge of coordinate transformations in calculus
  • Basic integration techniques involving differentials
  • Study coordinate transformations in calculus for volume calculations
  • Learn about the washer method for volumes of revolution
  • Explore advanced integration techniques involving non-standard differentials
  • Practice problems involving rotation around arbitrary lines
Students in calculus courses, particularly those studying volume calculations, educators teaching advanced integration techniques, and anyone interested in applying the disc method to complex rotational problems.
flyers
In my Cal 2 class we learned the disc method to rotate an area around an axis to obtain a volume. However we only rotated a function around either the x-axis or y axis. Let's say I take the function y=x2and y=x from the interval 0 to 1 and I want to rotate the area between these functions around the line y=x, can this be done? My teacher said something about tranforming the equations into standard form but also said we are not looking at these types of problem in my course.
The radius of your "disk" would be the line perpendicular to the axis of rotation- and that might be hard to find. Also the differential in the integral would not be "dx" or "dy" but some combination. Your teacher is probably right that the best method would be to transform the coordinate system.
