What Is the pH of a Saturated Zn(OH)2 Solution?
  • Thread starter Thread starter tua28494
    Chemistry Ph
The pH of a saturated Zn(OH)2 solution is calculated to be 8.5, based on the solubility product constant (Ksp) of 1.2 x 10^-17. The equilibrium expression Ksp = [Zn2+] [OH-]^2 is utilized, leading to the determination of hydroxide ion concentration [OH-] as 2.8 x 10^-6 M. The pOH is then calculated as 5.5, resulting in the final pH value using the formula pH = 14 - pOH. This calculation confirms that the approach and final result are reasonable.
  • Understanding of solubility product constant (Ksp)
  • Knowledge of chemical equilibrium and dissociation reactions
  • Familiarity with logarithmic functions for pH and pOH calculations
  • Basic concepts of acid-base chemistry
  • Study the impact of temperature on Ksp values for various compounds
  • Learn about the role of water dissociation in pH calculations
  • Explore the concept of common ion effect in solubility
  • Investigate the relationship between pH and buffer solutions
Chemistry students, educators, and anyone interested in understanding the solubility and pH relationships of metal hydroxides in aqueous solutions.
tua28494
What is the pH of a saturated Zn(OH)2 solution?
Ksp = 1.2 x 10^-17
Zn(OH)2 <----> Zn2+ + 2OH-
pOH = -log [OH-]
pH = 14- pOH
Ksp = 1.2 x 10^-17 = [Zn2+] [OH-]^2
- x +x +2x
1.2 x 10^-17 = [x][2x]^2 = 4x^3
x = 1.4 x 10^-6 M
[OH-] = 2x = 2.8 x 10^-6 M
pOH = - log 2.8 x 10^-6 = 5.5
pH = 14 - 5.5 = 8.5
Again I am learning this on my own and do not have a solution manual to the textbook I am using. So just s quick check would be greatly appricated. Thank you for your time.
Approach looks OK and final result seems reasonable.
Note that this is very close to the place were OH- from water dissociation may play an important role.
methods
  • · Replies 22 ·
