Oxidizer Strength: Potassium Nitrate vs Sodium Nitrate
  • Thread starter Thread starter samblohm
    Strength
The discussion centers on the comparative oxidizer strength of potassium nitrate versus sodium nitrate, exploring the underlying reasons for any differences in their oxidizing capabilities. Participants also delve into related comparisons involving potassium hydroxide and sodium hydroxide, as well as the influence of cation size and stability of reaction products.
  • Some participants question whether sodium nitrate is indeed a weaker oxidizer than potassium nitrate.
  • A participant suggests that potassium salts may sometimes act as better oxidizers than sodium salts, citing the oxidation of manganese compounds in different hydroxide melts.
  • There is a discussion about the role of oxygen as an oxidizer in molten hydroxides, with a focus on why it might be more effective in potassium hydroxide compared to sodium hydroxide.
  • Some participants propose that the size and charge concentration of sodium and potassium cations could influence the stabilization of reaction intermediates and products, potentially affecting the overall reaction outcomes.
  • One participant mentions the physical properties of sodium nitrate, such as its hygroscopic nature, which complicates its practical use compared to potassium nitrate.
  • There is a suggestion to consider the stability of different products formed during reactions, indicating that intermediate stabilization could alter the final results.
  • Another participant raises the idea that the stability of ion pairs may depend on the specific anion involved, leading to different behaviors in reactions.
Participants do not reach a consensus on the oxidizer strength of potassium nitrate versus sodium nitrate, with multiple competing views and uncertainties regarding the factors influencing oxidizing capabilities.
The discussion includes various assumptions about the role of cation size, stability of products, and the influence of different anions, which remain unresolved. The complexity of the reactions and the conditions under which they occur are acknowledged but not fully clarified.
samblohm
What makes something like Potassium nitrate stronger than Sodium Nitrate as an oxidizer?
Chemistry news on Phys.org
Are you sure that's indeed the case? That sodium nitrate is a weaker oxidizer?
methods
I suppose I should have used Chlorate instead as an example because I'm very sure that it's a stronger oxidizer.
This is an excellent question samblohm! I don't have an answer, but will add to the puzzle.
I've read things that seem to say that molten KOH is a stronger oxidizer than NaOH. Any idea on why this would be?
...the oxidation of MnO2 in a NaOH melt does not lead to the required Na2MnO4 (with hexavalent Mn) but only to Na3MnO4 with pentavalent Mn.
NaOH only takes Mn(IV) to Mn(V) in this case whereas KOH takes it to Mn(VI). Why?? This seems so strange to me.
I'd be very interesting in anybody who can reference some information pointing to the reason why it seems that potassium salts are sometimes better oxidizers than their sodium counterparts!
Be careful - neither is an oxidizer.
From what I understand, it is not NaOH that 'takes' Mn(IV) to higher oxidation state, oxidation takes place in molten NaOH, but NaOH is not an oxidizer.
The only thing I know for sure is that KNO3 was used instead of NaNO3 because of their physical properties - NaNO3 is much more hygroscopic, which makes its use more difficut in practice (black powder with sodium nitrate tends to clump).
Also - can you explain what you mean by "better oxidizer"?
I guess different outcome of the reactions can be attributed to the cation size - while neither K+ nor Na+ are directly involved in the oxidation, they can stabilize some byproducts or intermediates, shifting equilibrium, hence different outcome. It could be also interesting to compare standard enthalpies of products (like Na2CO3 and K2CO3 for example) to see where the energy goes.
methods
Yeah good point. O2 from air is the oxidizer in this case. So I should have asked: Why is O2 a more potent oxidizer in molten KOH than NaOH? Or alternatively, as you hint at, there might be some difference in the stability of the Na2MnO4 and K2MnO4.
That's not exactly what I am hinting at. Even if both salts have similar stability, could be there are other possible (by)products which differ in stability. These can modify the finall effect.
Sodium cation is smaller and its charge is more "concentrated" - thus its attraction with negative ions can be stronger than in the case of potassium. This can stabilize some substances.
Isn't this entirely dependent upon the anion in question? I would think, in general, when you are comparing cations of similar electronegativity, ion pairs of similar size would be stabler because this would allow for better crystal packing.
If we use melting point as a metric for stability (we could also use enthalpies but these values were easier to quickly look up), it's clear in the example of alkali chlorides that sodium chloride is the most stable because Na+ is similar to size to Cl-
LiCl:605C
NaCl:801C
KCl: 770C
RbCl: 718C
CsCl: 645C
In this case Li+ is smaller than Na+, but NaCl has the higher melting point.
Yes, it depends on the anion - but I have a feeling that you are thinking only about the final product. As I wrote before, to change the reaction outcome it is enough that some intermediate is stabilized better.
MnO4 (regardless of the charge) seems to be bulky, so could be that your idea (similar sizes ions making stabler compounds) could work here - while both sodium and potassium cations are much smaller, potassium is a little bit closer in size. But that's a speculation which can get us banned :wink:
methods
  • · Replies 17 ·
10K
