Register to reply
Single Phase
by deakn
Tags: phase, single
Share this thread:
deakn
#1
Apr16-10, 01:00 AM
P: 15
Hi,
I am struggling with finding info on Electrical Phases. I understand that Single Phase is simply one ac signal, and I understand that 3 phase is 3 independent ac signals, all of which are exactly 120 degrees out of phase. My struggle comes in when I think about 220 volt dryer hookup in my house. There are 3 legs...2 'hots' and a ground. The 2 hots are each 110 volts.
1. But are they in phase or out of phase? I think they are out of phase in order to get 220 volts between the hot legs, right?
2. Are they 180 degrees out of phase?
3.What makes them 180 degress out of phase?
Phys.Org News Partner Engineering news on Phys.org
Future phones to use blood and speech to monitor HIV, stress, nutrition
Neuron circuit may enable pitch perception applications
Quasi-distributed temperature sensors from draw-tower fabrication technology
vk6kro
#2
Apr16-10, 04:00 AM
Sci Advisor
P: 4,027
What you have in your house is nothing to do with the 3 phase high voltage power distribution system.
Out in the street somewhere there is a transformer that converts the voltage between two phases of the high voltage power supply to a centre-tapped 220 volt output from a single winding.
The opposite ends of this are out of phase with each other by 180 degrees. When one end swings positive relative to the centre tap, the other swings negative.
Other appliances and lighting in your house use the centre tap (as a neutral) and one of the outside legs (as an active) of this winding to get 110 volts.
This system is fairly unique to North America. Most other countries bring one of three phases or all three phases into the house at about 230 volts. High power (at about 400 volts) is available between the phases. Three phase motors are more efficient than single phase ones and self starting, too
sophiecentaur
#3
Apr16-10, 07:41 AM
Sci Advisor
Thanks
PF Gold
sophiecentaur's Avatar
P: 12,130
I think this is mostly a terminology problem.
Two wires will just have an alternating voltage (say 50Hz) between them. You might call this a 'single phase system'. Another two wires may have another 50Hz AC between them. These two signals may not be in phase with each other; there is a 'phase difference'. You can have three pairs of wires with 120 degrees of phase difference between them. Let's make the amplitudes of the voltage on all three pairs the same. If you take the appropriate wire of each pair and join them together, you will have a 'three phase' system. The common point is called the Neutral. Somewhere in the system, this is usually connected to an 'Earth' . If you take the three pairs and connect them to equal loads then very little current (zero) will flow into the Earth connection because the neutral currents will add up (in phase and amplitude) to zero at the common point. There will be a voltage between any two of the phases which is √3 times the voltage on one pair. This is the Vector Difference between the two so-called Phasors. The three 'live', physical connections are referred to as 'phases' - which could be viewed as an unfortunate choice of name.
If you have just two pairs carrying AC and the signals are in phase, you can connect one of each pair to a common point and you will get Zero Volts difference, connecting one way round and twice the voltage, connecting the other way. Again, this is the vector difference between the two signals.
The US domestic system (above) seems very bizarre, to me, but it is just the consequence of the way the system grew and the fact that someone chose 110V as the operating voltage. Cables would need to be so thick for supplying large loads that 'they' had to introduce this strange 'two phase' system which can deliver four times the power with the same cable thickness by supplying twice the voltage as an option.
(Power = V2/R).
It has caused a lot of confusion - especially to non US observers! - but it serves a purpose and allows a lower (and a bit safer) operating voltage for most domestic equipment.
It is the three phase system that is used, worldwide, for generation, distribution and large motors and it is this system which is most elegant and useful. The other system just gives you twice the volts.
deakn
#4
Apr16-10, 01:22 PM
P: 15
Single Phase
Quote Quote by vk6kro View Post
These two phases from the high voltage power supply are they 120 degrees out of phase of each other before they hit the transformer? what changes them to 180 degrees out of phase?
sophiecentaur
#5
Apr16-10, 02:06 PM
Sci Advisor
Thanks
PF Gold
P: 12,130
The voltage between two wires can't be "out of phase" it is just an alternating voltage between them. You can only compare the phases of two signals. If you refer the voltages of two of the three phase supply to Earth, then they will be 120 degrees out of phase. But, using one as a reference, the other will just have an alternating voltage. The magnitude of that voltage is given by the trigonometry of the Phasors.
It's a matter of terminology.
Okefenokee
#6
Apr16-10, 02:20 PM
P: 235
A typical house in the US uses this setup:
One of the power company's three-phase legs comes to an individual house. Power companies try to distribute the legs equally so that they each have the same load but that's a different story. If I remember correctly, a leg may be around 4kV at distribution level.
The leg is connected to center-tapped transformer at the house. The primary side is a single coil that connects to the distribution voltage. The secondary side of the transformer is a center-tapped coil and the tap is connected to the house's ground which ties it to 0V. The center-tapped coil is arranged so that the ends of the secondary coil are +120V on one side and -120V on the other side with respect to the grounded center-tap. Note, I don't mean that the voltages are literally positive or negative, instead they are out of phase by 180 degrees.
Smaller appliances can connect across one of the split 120V legs to ground. Larger appliances can connect across both 120V legs, and because they are out of phase by 180 degrees, they will get 240V.
Go look inside the circuit breaker box (carefully, after opening the main switch outside your house at the main box under the meter). You'll see that the box has three buses. The center bus is the 0V ground an the sides are the +/-120V legs. Look at how the big appliance lines and small appliance lines are connected.
ETA: Scratch that last part about looking inside the breaker box. Don't try this at home kids. (Are you a kid?)
mheslep
#7
Apr16-10, 03:58 PM
PF Gold
P: 3,097
Quote Quote by Okefenokee View Post
Nice summary.
berkeman
#8
Apr16-10, 04:09 PM
Mentor
berkeman's Avatar
P: 40,932
Quote Quote by mheslep View Post
Nice summary.
Agreed. Lots of good info in this thread, so I highlighted it. It's in Engineering Highlights now. Thanks folks.
sophiecentaur
#9
Apr16-10, 04:48 PM
Sci Advisor
Thanks
PF Gold
P: 12,130
Fame at last chaps!
vk6kro
#10
Apr16-10, 06:14 PM
Sci Advisor
P: 4,027
Good move.
Variations on this question come up all the time.
deakn
#11
Apr16-10, 06:41 PM
P: 15
Quote Quote by sophiecentaur View Post
Everyone else is saying they are out of phase by 180 degrees... are you saying this becuase they are only 180 degrees out of phase relative to the center tap?
deakn
#12
Apr16-10, 06:47 PM
P: 15
Here you say 2 phases of the high voltage power supply are connected to the transformer and further down the post someone quotes that one leg is attached to the transformer (assuming the other side is hooked up to earth). Which one is correct or can it be done either way? what would be the point of tapping off 2 phases of the highvoltage instead of just the one?
vk6kro
#13
Apr16-10, 09:33 PM
Sci Advisor
P: 4,027
It doesn't make much difference. In the US, as I understand it, the high voltage distribution system does not include a neutral. In other countries it does.
You can take the voltage between phases to the primary of the transformer or you can take the voltage from one phase to neutral to the primary of the transformer.
sophiecentaur
#14
Apr17-10, 10:59 AM
Sci Advisor
Thanks
PF Gold
P: 12,130
If you connect between two phases you will get 'root three' times the voltage.
But either the so called Star or Delta connections can be used. In the UK, it is more common, afaik, to have a three phase HV transformer to produce three low voltage , single phase supplies with a common Neutral. These are then distributed around a neighbourhood, houses being supplied with phase 1,2,3,1,2,3,1,2,3, alternately as you go down the road. It is discouraged to connect electrical supplies from a house to the adjacent house as this will involve the existence of 400V between points in the same premises and this is a potential hazard if you are not prepared for it.
sophiecentaur
#15
Apr17-10, 11:07 AM
Sci Advisor
Thanks
PF Gold
P: 12,130
Quote Quote by deakn View Post
I am, perhaps, being a bit picky but you can only have a phase difference between TWO signals. A signal must be the PD between two points. If you consider the phase of the voltages between the centre tap and one leg then the other leg, then they will be in antiphase. I think that's what you mean and I agree.
If you consider the potentials of the two legs relative to some other reference, then there could be a different value of phase difference - but this is not a likely scenario unless you happen to be a power engineer waving a phase meter around in a substation and connecting, willy-nilly to all possible terminals in sight!
Okefenokee
#16
Apr17-10, 12:32 PM
P: 235
That's exactly it. By the way, you hooked the house up with a delta source in your drawing. I'm pretty sure that delta is used for long distance transmission, because you only need three wires, but residential lines are in a wye configuration for safety (wye can be grounded). There's a delta-wye transformation somewhere in between long distance transmission and residential distribution.
Delta has no ground. The hot wires serve as both the send and return path of current. If the loads are balanced, there is no return current at all. Note that we're talking about current in the frequency domain here. If the loads become unbalanced, the voltages become unbalanced as the currents return through neighboring wires. In wye, the current always go out through hot wires and returns through the neutral. That means that each leg can draw whatever current it wants without disturbing the other legs.
The advantage of delta is that it only requires three wires as opposed to wye's 4 wires. The advantage of wye is that it can survive being unbalanced. Wye can be safer too because you can ground it. That's why both are used.
Deakn, maybe you could look at a diagram for a delta-wye transformer to get an idea of delta and wye are related. A "leg" is simply a sampling of one voltage difference.
Let's circle back around to your original question. I think there was a bit of initial confusion because the US system is totally different from European systems. The three-phase system is not important inside a US home. You won't have to deal with any three-phase power unless you work at an industrial park that uses lots of juice. You were right about the phases of the two buses being out of phase by 180 degrees. Vk's drawing shows how the transformer accomplishes that.
deakn
#17
Apr18-10, 07:11 PM
P: 15
In that picture drawing can i get more info explained on how the two phases that are taking from the powerplant that are 120 degrees out of phase relative to neutral are then changed to 180 degrees out of phase
vk6kro
#18
Apr18-10, 08:47 PM
Sci Advisor
P: 4,027
The voltage between phases goes right back to the generator at the power station, where three voltages are produced by a rotating machine.
They are then connected in a delta pattern for transmission. They pass through transformers to get different voltages, but always retain their original phase timing.
There is a very real, normal, (and deadly) AC voltage between any two phases and each phase is displaced 120 degrees from the other phase.
The voltage applied to the primary of the transformer is a perfectly normal AC voltage.
The other phase to phase voltages are the same, but occur 1/3rd of a cycle earlier or later.
A neutral may be introduced at one of the transformers or at the generating machine, but it does not affect the voltage between phases.
Register to reply
Related Discussions
Alternator Problems (3 phase and single phase AC Motor) Engineering, Comp Sci, & Technology Homework 3
Wye 3 phase to single phase distribution woes Electrical Engineering 9
3 phase vs. single phase power Electrical Engineering 13
Alternator Problems (3 phase and single phase AC Motor) Engineering, Comp Sci, & Technology Homework 0
3 phase 240 Delta Vs single phase 240 Electrical Engineering 18
