Traveling in an Expanding Universe
The discussion revolves around the implications of traveling in an expanding universe, particularly focusing on the behavior of galaxies and redshift measurements. Participants explore concepts from cosmology, including Hubble's Law, the nature of relative velocities in General Relativity, and the effects of the cosmological constant on travel to distant galaxies.
  • One participant proposes a scenario where galaxies are uniformly spaced in an expanding universe and questions the implications of redshift measurements on travel between them.
  • Another participant introduces Hubble's Law, explaining that recession velocities increase with distance, and discusses the concept of local rest frames in the context of relativity.
  • A participant raises questions about the constancy of Hubble's constant and its implications for the velocities of galaxies as they move in the Hubble flow.
  • Concerns are expressed about the definition of relative velocities in General Relativity, noting that these are only well-defined at a single point and can vary with coordinate choices.
  • Some participants speculate on the existence of galaxies in the observable universe that may never be reachable due to the effects of the cosmological constant and accelerated expansion.
  • There is a discussion about the implications of accelerated expansion for the ability to travel to distant galaxies, with some suggesting that many galaxies will remain out of reach regardless of travel speed.
  • A participant questions whether any particle can exceed the speed of light, leading to a clarification that nothing can exceed light speed in space, but space itself can expand without limits.
Participants express multiple competing views regarding the implications of redshift, the nature of Hubble's constant, and the effects of cosmic expansion on travel to distant galaxies. The discussion remains unresolved on several points, particularly regarding the reachability of certain galaxies and the interpretation of relative velocities.
Limitations include the dependence on specific definitions of distance and velocity in cosmology, as well as the unresolved nature of certain mathematical aspects related to the expansion of the universe.
JWINC
For starters let me say that reading about and pondering cosmology is only a hobby, I have no formal education in this arena, although I am returning to school this spring to do just that. That being said, the following query may be foolish for some basic reasons I have missed, or not come upon yet, but I would be happy to know what they are.
For the sake of this question let us say that the Milky Way Galaxy is at the center of a sphere, the sphere being our expanding universe. As we draw a radial line from the center of the sphere (A) out to its face our line passes through 5 other galaxies (B,C,D,E,F). Each of these galaxies are separated by each other by a decent amount of space, say 10 billion light years, and measures a red shift to its nearest galactic neighbors sufficient to put their speed of separation at 1/4 the speed of light.
Galaxy A being the Milky Way, here are the 6 galaxies connected by a straight line each uniformly spaced.
A----B----C----D----E----F
My understanding is that since we on A measure a redshift of X to B and B measures a redshift of X to C we on A measure a redshift of 2x to C. Therefor we on A would measure a redshift of 5x to F, and since X=1/4 the speed of light galaxy F is "moving away" from A at a speed greater than the speed of light?
If that is the case then even though F is "moving away" from A at greater than the speed of light it is still possible to travel from A to F while moving at only slightly more than 1/4 the speed of light?
Space news on Phys.org
That's just about right. What you need here is Hubble's Law:
[tex]v=Hr[/tex]
where v is the recession velocity of a distant object (one of your galaxies), H is Hubble's constant, and r is its distance. This famous relation indicates that recession velocities grow with distance (more space is expanding between distant objects than objects close together, or, as Gertrude Stein would say, "there's more there there.") You'll notice that there is a distance, r= c/H, at which distant objects begin to recede at light speed. This is perfectly fine and consistent with relativity. Each galaxy is locally at rest (not moving relative to the background spacetime -- this is best visualized by drawing a grid, placing galaxies at points on the grid, and then stretching the grid to simulate expansion). So, there will be no problem with you traveling to one of these far off galaxies. Eventually you will reach a distance from your starting point at which your destination galaxy is no longer receding at light speed.
Very interesting. This prompts the question: is H constant. When B moves with the Hubble flow to the position of C when we started, is it now moving with twice the velocity?
Related question: in special relativity, Einstein tossed out the notion of simultaneity. How does that work in GR? What does it even mean to say "the position of C when we started"?
Just trying to wrap my head around this.
The primary issue here is that the there is no strict way to determine the relative velocities of far-away objects. Yes, this is one way to talk about the velocity between, say, galaxy A and galaxy F. And by this definition, yes, most visible galaxies in our universe always are (and always have been) moving away at faster than the speed of light.
But I could merely change coordinates and end up with there being no relative velocity at all (e.g. if my coordinates move along with the expansion: galaxy F is always just as many grid points away from galaxy A as it always was).
In fact, relative velocities are only well-defined in General Relativity at a single point. This means that you can definitively say that galaxies A and F are not outrunning any light rays that pass by them. But you can't say they're not outrunning light rays that are far away.
Just a thought from another hobbyist: Is this really 'compatible'...??
To me it looks like JWINC is talking about the observable universe (46 bly), and bapowell is talking about the Hubble volume (13.8 bly)...?
Surely, there must be galaxies in the observable universe which we can never 'travel' to, or??
Provided that there is actually a cosmological constant, yes, even light rays sent out from the Earth today can never reach many galaxies that we can see.
Okay, thanks Chalnoth. And I take it, since the http://en.wikipedia.org/wiki/Supernova_Cosmology_Project" has shown that there is not only an expansion, but an accelerating expansion – the 'traveling' gets even tougher...
The accelerated expansion is actually necessary for there to be places in the observable universe that will forever be out of reach.
Independent of the speed of the traveler?
Edit: Stupid question, forget it. You are talking about c, right?
Yes :)
hehe... :blushing:
No. It's proportional to the energy density of the universe, and hence is a function of time; however, it's effectively a constant: it's value today is going to be just about its value 100 years from now.
I don't think this adds any complication, as long as we establish a frame of reference. If you are an observer comoving with the expansion, and galaxy C is as well, then the distance between yourself and galaxy C is just the proper distance. No need to worry about issues of simultaneity.
can any particle in our universe travell faster than the speed of light ? sir i heared that some time it is found that some paticals are found which emits the rays & speed of rays is 4 times than the speed of light ? sir some time we say that no body can run faster than the light sir i am in totally confusion please email me my answer via email and solve my tension
Rule #1: Absolutely nothing can exceed the speed of light, moving in space.
Rule #2: Space itself has no speed limit.
Check out http://en.wikipedia.org/wiki/Faster-than-light" for more info.
  • · Replies 39 ·
  • · Replies 23 ·
  • · Replies 19 ·
  • · Replies 65 ·
