How Do Independent Current Sources Work Without a Potential Drop?
The discussion revolves around the functioning of independent current sources, particularly focusing on their operation without a potential drop across them. Participants explore theoretical and practical aspects, including the implications of current sources in real-world applications and their characteristics in various configurations.
  • Some participants express difficulty visualizing current sources that deliver constant current without a potential drop, questioning their existence as practical devices.
  • Others argue that real-world current sources require a minimum voltage drop, referring to the concept of "compliance" and the need for transistors to operate in their linear region.
  • A participant discusses the operation of generators in current source mode, explaining the relationship between torque, speed, and voltage, and noting the inefficiencies associated with this approach.
  • Another participant suggests that an ideal current source would have infinite dynamic output impedance, making the output current independent of load, but acknowledges the impracticality of such a solution in favor of active feedback methods.
  • One participant elaborates on the necessity of adjusting source voltage and resistance to achieve desired current levels across varying load resistances, emphasizing the role of feedback control in practical implementations.
Participants do not reach a consensus on the nature of current sources, with multiple competing views on their theoretical and practical implications remaining unresolved.
Limitations include the dependence on definitions of ideal versus practical current sources, the assumptions regarding load resistance, and the unresolved complexities in the mathematical modeling of current sources.
SpartanG345
I still can't visualise them.
They deliver the same current all the time, however there is no potential drop across them. Is it just a theoretical device that doesn't exit?
I am sure current sources do not add new charge into the circuit, but rather move charges around but this requires a potential difference.
Yes, absolutely. A current source in the real world has to have some minimum voltage drop across it. The term used is "compliance". At a minimum, the current source is a transistor, controlled to deliver a (relatively) constant current. The transistor needs to operate in the linear region, and you probably know what kind of minimum voltage drops that entails.
A generator can be operated in current source mode by forcing a constant torque. In commercial power generation, the turbine is run at constant speed, in order to produce constant voltage. Load variations require that fuel burning varies to keep constant speed. Thus a CVS requires operation at constant speed & variable torque. A CCS requires constant torque & variable speed.
The voltage would be simply the current value I, times the load resistance R. For a dead short, power is near zero and speed is minimal. As load resistance R increases, the same torque results in higher speed and higher voltage.
The reason it is never done this way is that of losses. I^2*R is much greater than V^2*G. With CV, the full voltage is always generated, but current is that of the demanded load, 35%, 51%, etc. With CC, the current is always generated at 100%, with voltage varying with loading. Losses are greater in this case.
In addition, the CV is stepped up w/ xfmrs to increase V & decrease I. Again, losses are cut this way. If high temperature superconductors ever become real & affordable, constant current might be realized.
However, CV has another advantage - constant frequency. CF makes synchronous motors run at a fixed speed, and that is useful. CC results in variable frequency, not bad, but synchronous operation of clocks would be lost. Make sense?
Claude
If there were no PD across the source then it would have zero impedance. A constant current source will have whatever PD is needed to make the required current to flow through the load - the load resistance must have no effect on the current through it. So, for a 'passive realisation of this, the source resistance and source voltage need to be as high as necessary to achieve this over the desired range of load and accuracy of Current value.
With an active device involved (an amplifier) you can get away with a much lower source voltage and just vary the PD across the source resistance to get the current you want (over the desired range of load resistances). You need the source voltage to be such that the current through the Highest required Load resistance is what you want. At this point, the series resistance would be zero (if you had a suitable device in series). But a practical device will have a certain minimum resistance. So the source voltage needs to be enough to obtain the desired current through (maximim) load resistance and (minimum) source resistance in series.
At the other end (zero load resistance), the source resistance needs to be
RS = source voltage / desired current.
The source resistance must be controlled to be some value between the two extremes by suitable feedback control.
An ideal current source has an infinite dynamic output impedance, so the output current is independent of the termination. For example, a reasonably good 1-milliamp current source is 1000 volts in series with a 1 megohm resistor. But this is an awkward solution, so using active transistor feedback is easier. See simple 1-milliamp current source with feedback in thumbnail. In this circuit, Q2 controls the base input to Q1 such that the base-emitter voltage of Q2 is 0.75 volt. R2 pullup should be as high as possible to minimize the Q2 emitter current.
Bob S
  • · Replies 42 ·
9K
27K
