What are the properties of a normalized wave function?
The discussion revolves around the properties of a normalized wave function in quantum mechanics, specifically focusing on a piecewise-defined wave function. Participants are tasked with normalizing the wave function and exploring its implications regarding the probability of finding a particle in certain regions.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the normalization condition for the wave function and express uncertainty about how to apply it. Some attempt to derive the normalization constant A by integrating the square of the wave function over its defined intervals.
There is an active exploration of the normalization process, with various participants attempting to set up the necessary integrals. Some guidance has been offered regarding the need to combine integrals from different segments of the wave function, and there is acknowledgment of the importance of squaring the normalization constant in the integrals.
Participants are working under the constraints of a homework assignment, which may limit the resources they can use. There is also a discussion about the assumptions made in the problem setup, particularly regarding the constants involved in the wave function.
vorcil
At time = 0 a particle is represented by the wave function
[tex]\Psi(x,0) = \left\{ \begin{array}{ccc}<br /> A\frac{x}{a}, & if 0 \leq x \leq a, \\<br /> A\frac{b-x}{b-a}, & if a \leq x \leq b, \\<br /> 0, & otherwise, <br /> \end{array} \right [/tex]where A, a, and b are constants.
(a) Normalize [tex]\Psi[/tex] (that is, find A, in terms of a and b).
(b) where is the particle most likely to be found, at t =0?
(c) What is the probability of finding the particle to the left of a? Check your result in the limiting cases b=a and b = 2a
(d) what is the expectation value of x?
My attempt:
no bloody idea where to start,
I know that to normalize a function,
[tex]\int_{-\infty}^{\infty} |\Psi(x,t)|^2 dx =1[/tex]
But have no idea how I am supposed to incorporate that into my question...
I need EXAMPLES
I have no idea how to solve something I've never seen before!
ok I'm just going to start guessing here,
if someone would be kind enough to correct me on mistakes
since I want to find A,
and the wave function [tex]\Psi(x,0) = A \frac{x}{a}[/tex]
if I square it, it should = 1?
[tex]\Psi(x,0)^2 = A^2 \frac{x^2}{a^2} ==1[/tex]
not too sure where to go from here
the same with the middle equation,
[tex] \Psi(x,0)^2 =(A\frac{(b-x}{b-a})^2) =1[/tex]
You have the right idea but the two integrals added together should be equal to one I do believe. Also be sure to square the A/(b-a) on the second integral.
When I am normalizing the wave function, do I add the equations from all the parts of the wave function?
i.e
[tex]\int_{-\infty}^{0} +\int_{0}^{a}+\int_{a}^{b}+\int_{b}^\infty[/tex]
so adding that to concept to my question,
i'd get
[tex]|\Psi(x,0)|^2 = \int_{-\infty}^0 0^2dx + \frac{A^2}{a^2}\int_0^a x^2 dx + \frac{A}{(b-a)} \int_a^b (b-x)^2 dx + \int_b^\infty 0^2dx =[/tex]
[tex] = |\Psi(x,0)|^2 = \frac{A^2}{a^2}\int_0^a x^2 dx + \frac{A^2}{(b-a)^2} \int_a^b (b-x)^2 dx [/tex]
then uh simplifying and such i get,
(since A^2 is in both equations)
[tex]\left( A^2 \left[ \left( \frac{1}{a^2} \frac{x^3}{3} \right) + \left( \frac{1}{(b-a)^2} \int_a^b (b-x)^2 dx \right) \right] \right) =1[/tex]
That is almost correct except A/(b-a) should be squared as well and then all of that will be equal to one. Then you should do each integral then just solve for A.
how do I integrate (b-x)^2 ?
[tex]\int (b-x)(b-x)dx = \int (b^2 - 2bx + x^2 )dx= b^2 -\frac{2bx^2}{2} + \frac{x^3}{3}[/tex]
? then i evaluate that at [tex]& \left equation \right|_{a}^{b}[/tex]
For b2, you can think of that as b2*x0. So when you take the integral of that, you would end up with b2*x1. Other than that, everything else looks correct.
[tex]\int (b^2 - 2bx + x^2) dx = b^2x - \frac{2bx^2}{2} + \frac{x^3}{3}[/tex]
[tex] <br /> b^2x - bx^2 +\frac{x^3}{3}<br /> [/tex]
what now?
I was shown that the answer to that integral was
[tex]-\frac{(b-x)^3}{3}[/tex]
but how do i get that?
from
[tex]\int_a^b (b-x)^2 dx[/tex]
to
[tex]\left -\frac{(b-x)^3}{3} \right|_a^b[/tex]
what now?
from
to
They used u=(b-x) => du=-dx
You are on a roll and almost there -- keep up the good work!
embarassing
but I can't integrate that, I don't know how
can someone please explain to me how to integrate it?
vorcil said:
embarassing
You don't have to do it the way they did it. Just expand (b-x)2, and make three simple integrals. You should be able to do those.
[tex]\int_b^a (b-x)^2dx \\[/tex]
[tex]\int_b^a (b-x)(b-x)dx \\[/tex]
[tex]\int_b^a (b^2 +x^2 -2bx)dx \\[/tex]
[tex]b^2x + \frac{x^3}{3} + \frac{-2bx^2}{2} \\[/tex]
i Don't see how that equation,
[tex]b^2x + \frac{x^3}{3} + \frac{-2bx^2}{2}[/tex]
equals
[tex]\frac{(b-x)^3}{3}[/tex]
can someone just explain please
They do it by making the "u" substitution I wrote in the earlier post. The integral becomes -u2du
Integrate that, then put the b-x back into u.
  • · Replies 20 ·
  • · Replies 19 ·
  • · Replies 43 ·
