Centripetal Force and Tangential Velocity
The discussion centers on calculating the mass of an object that can be spun in a circular motion using a string of 4.23 m length, which can support a mass of 0.025 kg vertically. The string breaks when the tangential velocity reaches 5.1 m/s. Key equations include Centripetal Force = (mass)(tangential velocity)2 / radius and Tangential Velocity = (angular speed)(radius). Participants emphasize the importance of analyzing the forces acting on the mass to determine the unknown weight.
  • Understanding of centripetal force and its formula
  • Knowledge of tangential velocity and its relationship with angular speed
  • Ability to draw and interpret free-body diagrams
  • Familiarity with basic physics concepts related to mass and force
  • Study the derivation of the centripetal force equation
  • Learn how to calculate angular speed from tangential velocity
  • Explore free-body diagram techniques for analyzing forces
  • Investigate the relationship between mass, tension, and acceleration in circular motion
This discussion is beneficial for physics students, educators, and anyone interested in understanding the principles of circular motion and force dynamics.
x0ji11y
Suppose a string of negligible mass can support a mass of .025 kg when hanging vertically. The string is 4.23 m long (radius). If you add another weight and spin the string horizontally in a circular pattern above your head, the string will break upon reaching a tangential velocity of 5.1 m/s. What is the mass of the weight?
Angular displacement = (arc length) / (radius)
Centripetal Force = (mass)(tangential velocity)(tangential velocity) / (radius)
Centripetal Force= (mass)(radius)(angular speed)(angular speed)
Tangential Velocity=(angular speed)(radius)
I have no idea where to get started, considering you're given neither the mass nor the force to work with. I'm thinking that you need to start by using the fact that it can support a 25 g mass vertically, but i don't know how to calculate the force from that, given that the tangential velocity is zero. Any help would be greatly appreciated! Thank you! :)
Start by drawing the free-body diagram for the 25-g mass when it's suspended vertically. You should be able to find the tension in the string easily.
  • · Replies 20 ·
  • · Replies 17 ·
18K
