How to Choose the Right Capacitor for Smoothing a Full-Wave Rectified Output?
  • Thread starter Thread starter neduet
    Capacitor
The discussion revolves around selecting an appropriate capacitor for smoothing the output of a full-wave rectified waveform, specifically addressing the ripple voltage and load current considerations. Participants explore the implications of different capacitor sizes and the potential use of voltage regulators in achieving a smoother DC output.
  • One participant inquires about the appropriate capacitor rating to smooth a 6-volt peak output from a full-wave rectifier, specifying a frequency of 50 Hz and a load current in the milliamp range.
  • Another participant notes that some ripple will always be present and emphasizes the need to define acceptable ripple levels and maximum load current for the application.
  • A specific example is provided where a 1000 µF capacitor results in approximately 0.8 volts peak-to-peak ripple with a 150-ohm load drawing 40 mA, highlighting the trade-off between capacitor size and charging current.
  • There is a suggestion that using a voltage regulator could improve the output quality, but it is noted that a minimum input voltage of around 9 volts is necessary to achieve a regulated 6-volt output.
  • Concerns are raised about ensuring that ripple calculations are accurate to prevent the output from dropping below the minimum voltage required for the regulator to function properly.
Participants express differing views on the best approach to smoothing the output, with some advocating for larger capacitors and others suggesting voltage regulators. The discussion remains unresolved regarding the optimal solution and the acceptable levels of ripple.
Limitations include the lack of specific ripple tolerance values and the dependence on load current specifications, which may affect the choice of capacitor and regulator. The discussion does not fully resolve the mathematical implications of ripple calculations.
neduet
Need capacitor for smoothing?
hello friends
if i have 6 volt peak full-wave rippled output wave form comes from full-wave rectifier. the what rating capacitor (in faraday) i connected with it to make it smooth dc wave.
thanks a lot
frequency is 50hz and 220volt input
and out from rectifier
and my load demands taking current about some mAmp
There always will be some ripple. You need to define how much ripple you can tolerate. The amount of ripple will also increase with the load current so you also need to define the maximum load current for the ripple specification.
As an example, with your supply and a 150 ohm load (40 mA), and a 1000 uF capacitor, the ripple would be about 0.8 volts p-p.
You could use a larger capacitor, but the charging current for a bigger capacitor quickly gets very large. Even a 1000 uF capacitor needs about 500 mA charging pulses to charge it.
It is usually better to use a voltage regulator, but you would need at least about 9 volts from the power supply to get 6 volts out and this would have to be filtered.
However, the output of a voltage regulator can be almost perfect DC with only slight ripple and noise visible on an oscilloscope.
True, but even so you still need to be able to calculate how much ripple you'll have so that you don't go below the minimum voltage the regulator can regulate.
10K
  • · Replies 63 ·
