Points where normal at point on surface equals line from origin to that point
The problem involves finding points on the paraboloid defined by the equation z = x² + y² - 1, where the normal line at those points coincides with the line drawn from the origin to the point on the surface.
  • Mixed
  • Participants discuss the use of the gradient to find the normal vector and its relationship to the line from the origin. There are attempts to equate components of the normal vector with those of the line from the origin, leading to a system of equations.
Some participants are exploring the algebraic manipulations required to solve the system of equations derived from the normal vector. There is recognition of potential errors in calculations, and clarification is sought regarding the interpretation of the equations.
There is mention of a specific approach involving the radius of a cross-section of the paraboloid, indicating a geometric perspective on the problem. Participants express confusion about the algebraic results and the implications of the derived equations.
Jamin2112
Find the points (x,y,z) on the paraboloid z=x2+y2-1 at which the normal line to the surface is the line from the origin to the point (x,y,z).
normal line means take the gradient, <∂F/∂x, ∂F,∂y, ∂F,∂z>, and evaluate at the point
n= -2xi + -2yj + 1k, where i=(1 0 0)T, j=(0 1 0)T, k=(0 0 1)T.
So we want an (x,y,z) that such that the normal vector n is a scalar multiple of xi + yj + (z=x2+y2+1)k.
<-2x,-2y,1> = ß<x,y,x2+y2+1>
<-2,-2,0> = <ß, ß, ß(x2+y2)>
Am I doing this right? Something ain't working.
Jamin2112 said:
So we want an (x,y,z) that such that the normal vector n is a scalar multiple of xi + yj + (z=x2+y2-1)k.
This is a reasonable approach, yes. Note that I corrected your sign above: [tex]z = x^2 + y^2 - 1[/tex], not [tex]z = x^2 + y^2 + 1[/tex].
Jamin2112 said:
<-2x,-2y,1> = ß<x,y,x2+y2-1>
How did you get from the first line to the second? It looks like you divided the first component of your vector equation by [tex]x[/tex], the second by [tex]y[/tex], and then tried to add something or other to the third. While in theory you could organize your manipulations that way (except that whatever you did to the third component is wrong), in practice it's a bad idea.
The equation [tex]\langle -2x, -2y, 1\rangle = \beta \langle x, y, x^2 + y^2 - 1 \rangle[/tex] translates into the system of equations [tex]\begin{cases}-2x = \beta x & \\ -2y = \beta y & \\ 1 = \beta(x^2 + y^2 - 1) & \end{cases}[/tex]. Proceed from there.
I just tried to get the components to match up; for example, -2xi=ßxi. But now I see what's happenin'.
Actually, I don't see what's happening. ß would be -2, looking at the first two equations, but then plugging that into the third gives the equation x2 + y2 = -1. Explain how to solve that system.
No, it doesn't; check your algebra. Also, [tex]\beta = -2[/tex] is not the only possible solution to the first two equations.
That's not very polite.
Correct.
Incorrect. Check your math.
For some reason, I'm not getting this problem. The wires in my brain must be crossed.
So what I did is just say z = r2 - 1, where r is the radius of the cross section of a plane z=c that cuts through the paraboloid. Then dz/dr=2r, meaning that at r=1/2, a scalar multiple of the normal line will pass through the origin.
