Heat equation and energy transport.
The discussion focuses on solving the heat equation for a rod with uniform density \(\rho\) and length \(l\), where the internal energy density is defined as \(E = c(T - T_0) + E_0\). The time-independent solution to the heat equation \(\frac{\partial T}{\partial t} = \kappa \nabla^2 T\) is derived as \(T(x) = \frac{T_l - T_0}{l}x + T_0\). The energy transport per unit time at the end of the rod is calculated using Fourier's Law, resulting in the expression \(q'' = \rho c \kappa \left(\frac{T_0 - T_l}{l}\right)\). The total thermal energy in the rod is determined through integration, yielding \(E = \rho S l \left[\frac{c (T_l - T_0)}{2} + E_0\right]\).
  • Understanding of the heat equation and its applications.
  • Familiarity with Fourier's Law of heat conduction.
  • Knowledge of energy density concepts in thermodynamics.
  • Basic calculus for integration and differential equations.
  • Study the derivation and applications of the heat equation in different geometries.
  • Learn about Fourier's Law and its implications in heat transfer analysis.
  • Explore energy density calculations in thermodynamic systems.
  • Investigate numerical methods for solving partial differential equations like the heat equation.
Students and professionals in physics and engineering, particularly those focusing on thermal dynamics, heat transfer analysis, and mathematical modeling of energy transport in materials.
center o bass
I have a rod of density [tex]\rho[/tex] and length [tex]l[/tex]. It's located at [tex]0\leq x\leq l[/tex]. The density of internal energy per mass is [tex]E = c(T-T_0) + E_0[/tex] where T is the tempertature in Kelvin,[tex]E_0[/tex] is a constant and [tex]c[/tex] is the specific heat capacity. We assume that the temperature is not varying across the rodd. The temperature at the two ends of the rod is [tex]T_0, T_l[/tex]
a) this question was to find the time independet solution to the heatequation
[tex]\frac{\partial T}{\partial t} = \kappa \nabla^2 T[/tex] and I found this one by using the conditions to be
[tex]T(x) = \frac{T_l - T_0}{l}x + T_0[/tex]
b) Find the transport of energy, per unit time, out of a cross-section of the rod at [tex]x = l[/tex].Also find the total thermal energy in the rod.
Im thinking that the solution to this probably is a flux integral, but I don't know how to proceed and what to integrate.
Transport of energy, per unit time, out of a cross-section of the rod. That sounds like heat flux. We use Fourier's Law in order to obtain the expression for heat flux.
[tex]q'' = -k \frac{dT}{dx} = - \rho c \kappa \frac{dT}{dx}[/tex]
[tex]q'' = \rho c \kappa \left(\frac{T_0 - T_l}{l} \right)[/tex]
Now, in order to find the total thermal energy of the rod we must integrate the energy density with respect to mass
[tex]E = \int_0^m \hat{E} \ dm[/tex]
Let S be the cross-section area of the rod, then
[tex]dm = \rho S dx[/tex]
[tex]E = \rho S \int_0^l \left[c (T_l - T_0) \frac{x}{l} + E_0 \right] dx[/tex]
[tex]E = \rho S l \left[ \frac{c (T_l - T_0)}{2} + E_0 \right][/tex]
  • · Replies 18 ·
