Mechanics question - circular motion
The problem involves a yo-yo of mass m swinging in a vertical plane from a string of length ℓ. The original poster seeks to determine the angular speed ω as a function of the angle θ, using principles of conservation of energy.
  • The original poster attempts to apply conservation of energy to derive an expression for angular speed. They express potential energy at different heights and question the correctness of their approach compared to their professor's method.
Participants are actively discussing the potential energy expression used by the original poster, with some questioning the assumptions made regarding height and potential energy at different angles. Clarifications are being sought regarding the derivation of the potential energy expression.
There is a focus on the definitions of height and potential energy in relation to the pivot point of the yo-yo, with some participants noting discrepancies in the original poster's reasoning.
tjackson3
A yo-yo of mass m , on a string of length [itex]\ell[/itex] is held horizontally and then released, as shown in the diagram. Assume that there is no friction and that the yo-yo swings freely in a vertical plane. Give your answers in terms of m, [itex]\ell[/itex], [itex]\theta[/itex], and g.
Diagram:
[PLAIN]http://img43.imageshack.us/img43/6735/physprob2.png
The part I'm stuck on: What is the angular speed [itex]\omega = \dot{\theta}[/itex] as a function of [itex]\theta[/itex]?
Kinetic energy: [tex](1/2)mv^2 = (1/2)m\omega^2\ell^2[/tex]
The way I solved it was using conservation of energy. If we take the bottom of the arc to be zero, the yo-yo was dropped from a height [itex]\ell[/itex]. Then at some angle [itex]\theta[/itex], the yo-yo would be at a height of [itex]\ell\cos\theta[/itex] (and have a corresponding potential energy of [itex]mg\ell\cos\theta[/itex]). So the equation becomes
[tex](1/2)m\omega^2\ell^2 + mg\ell\cos\theta = mg\ell[/tex]
After some algebra, the answer comes out to be
[tex]\omega = \sqrt{ 2g(1-\cos\theta) /\ell}[/tex].
(for some reason, the LaTeX coding is being silly with the square root; however, the entire expression is supposed to be under the square root)
My professor does it differently. In his solution, he uses conservation of energy with the equation
[tex](1/2)m\omega^2\ell^2 = mg\ell\cos\theta[/tex]
and solves from there to get the same thing I got except with just [itex]\cos\theta[/itex] where I have [itex]1-\cos\theta[/itex]. What is wrong with my reasoning here?
Thanks for your help!
tjackson3 said:
Diagram:
Looking at your diagram, when [itex]\theta=0[/itex], the mass will be at the bottom of the arc and should have zero potential energy (or at least less than it had at the top of the arc)...what does your formula for the potential energy give at [itex]\theta=0[/itex]?
Then you'd get an angular velocity of zero, which now that you mention it, does not make sense. However, where does the mistake in my reasoning come in?
Your expression for the potential energy is clearly incorrect...how did you derive it?
I just derived it from the expression for gravitational potential energy, using [itex]\ell\cos\theta[/itex] as the height.
[itex]\ell\cos\theta[/itex] is the distance below the pivot...not the height:wink:
Ohhh haha, thank you! :)
  • · Replies 21 ·
  • · Replies 23 ·
