Measuring Fluid level using a thermistor.
This discussion focuses on using thermistors to measure fluid levels. When a thermistor is submerged in a liquid, its temperature and resistance remain stable; however, if the liquid level drops and the thermistor is exposed, its temperature increases and resistance rises, signaling a change in logic state. The conversation emphasizes the importance of supporting circuitry in determining the logic output based on resistance levels. Additionally, it mentions the availability of NTC thermistors in metal sleeves from US Sensors for practical applications.
  • Understanding of thermistor operation and characteristics
  • Knowledge of voltage sources and current limiting techniques
  • Familiarity with logic levels and digital signal processing
  • Basic principles of fluid dynamics and temperature measurement
  • Research the specifications and applications of NTC thermistors from US Sensors
  • Learn about current limiting techniques to prevent thermal runaway in thermistors
  • Explore circuit design for integrating thermistors with microcontrollers for fluid level detection
  • Study the impact of temperature on resistance in thermistors and its implications for measurement accuracy
Engineers, electronics hobbyists, and researchers interested in fluid level measurement, thermistor applications, and sensor integration in electronic systems.
Robbie-Eng
Hey
I've been writting reports on strain gauge and thermistor.
Ive completed my strain gauge report and now i am working on my thermistor report...ive been doing some research on them and i was wondering if this is the correct information i have gathered.
so
I have been asked from my lectuar to produce a report on a thermistor, but using the thermistor to measure fluid level.
here is what i have gathered so far:
When a thermistor is driven by a voltage source, it heats up. If submerged in a liquid, its temperature, and therefore its resistance, will remain relatively constant—as long as the liquid temperature remains relatively constant. If the liquid level drops, however, the thermistor becomes exposed, the heat dissipating effect of the liquid vanishes, the temperature rises, and—for a positive-TC element—the resistance increases.
so if to measure the level of the fluid, if the thermistor is positioned at that level and when submerged in the liquid its resistance remains low giving out a logic 0, but if exposed then its resistance rises causing the thermistor to heat up rapidly, and from this it signals a logic 1.
Is this correct in anwway?
Thanks
Robbie
Sounds reasonable
Whether a high/low resistance gives a 1/0 depends on the supporting circuitry of course.
Yep, sounds good. Just be careful that you limit the maximum current or it could go into thermal run away. We did this a few times in the lab for grins :)
PS I think US sensors still makes NTC thermistors in metal sleeves that screw into a tank.
- Mike
  • · Replies 17 ·
10K
  • · Replies 31 ·
