Calculating Magnetic Torque: Circular Wire Loop in a Uniform Field
  • Thread starter Thread starter Dx
    Magnetism Torque
The discussion revolves around calculating the magnetic torque on a circular loop of wire placed in a uniform magnetic field. The loop has a radius of 0.5m, a current of 2A, and is subjected to a magnetic field strength of 0.30T. Participants explore the implications of the loop's orientation relative to the magnetic field.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the formula for magnetic torque and the significance of the loop's orientation, particularly the misunderstanding regarding sine and cosine values. There is also confusion about the definition of the number of turns in relation to the loop.
The discussion is ongoing, with participants clarifying misunderstandings about trigonometric functions and the number of turns in the loop. Some guidance has been offered regarding the definitions involved, but no consensus has been reached on the final answer.
There is mention of the problem not having an answer provided in the textbook, which adds to the uncertainty in verifying the calculations. Participants express a desire to seek further clarification in class.
Dx
A circular loop of wire of radius .5m is in a iniform magnetic field of .30T. the current in the loop is 2A. what is the magnetic torque when the plane of the loop is parallel to the magnetic field?
Ok i first misread this and assued that it meant parallel or sin(90 degrees) which equals 0.
I have thus far...
A = PI * r^2 = PI * .5^2 = .785 now plug thast into this formula.
t = NIAB = (?)(2)(.785)(.3). I know that to get the number of turns is number of loops divided by length. But there is no such animal, I have a feeling that I am using the wrong formula perhaps or have done something incorrect. I've tripled check and still get .471 as my answer. What am I doing wrong?
dx :wink:
"Ok i first misread this and assued that it meant parallel or sin(90 degrees) which equals 0."
Actually, sin(90)= 1, not 0. Did you mean cos?
You are told that the loop is parallel to the exterior magnetic field. That means that the loop's magnetic field (which is perpendicular to the plane of the loop) is perpendicular to the exterior magnetic field.
" I know that to get the number of turns is number of loops divided by length"
I don't understand this- the number of turns IS the number of loops. Do you mean "loops per unit length"?
"Actually, sin(90)= 1, not 0. Did you mean cos?"
I already knew that but thought I read somewhere in the book about it. Ill double check cuase your correct.
Yes!
What am I doing wrong Ivy? I need help, please?
Dx
:wink:
a circular LOOP means that the no of turns=1.
this gives the answer 0.471 N so i think your answer is correct.
Does the book gives different answer?
No! This question is one of those w/o the answer in the back of the book. I am going to ask again in class tomorrow, I do also beilive its correct. Thanks!
Dx :wink:
  • · Replies 37 ·
