Antimatter - could it ever be utilized as poss. energy source?
The discussion revolves around the potential utilization of antimatter as an energy source, exploring theoretical and practical aspects of antimatter production, storage, and energy generation. Participants consider the implications of conservation of energy, the challenges of containment, and the feasibility of using antimatter in spacecraft or other applications.
  • Some participants speculate that the energy required to create antimatter exceeds the energy gained from its annihilation with matter.
  • Others suggest that the conservation of energy plays a crucial role in the feasibility of using antimatter as an energy source.
  • There are challenges related to containing antimatter, which requires strong magnetic fields, and the energy costs associated with this containment.
  • Some participants propose that antimatter could be more suitable for energy storage rather than direct power generation due to its high energy density.
  • It is noted that antimatter is produced in small quantities in particle accelerators, primarily through pair production, which involves high-energy photons creating electron-positron pairs.
  • Concerns are raised about the practicality of sourcing antimatter from the universe and the difficulties in detecting it, as it behaves similarly to matter except for its charge.
  • A few participants draw parallels between antimatter and nuclear power, discussing the relative simplicity of generating power from antimatter compared to nuclear energy.
  • Questions arise regarding the relationship between the speed of colliding particles and the energy produced during annihilation.
Participants express a range of views on the feasibility of using antimatter as an energy source, with no consensus reached. Some agree on the challenges of containment and energy costs, while others propose different applications for antimatter.
Participants acknowledge limitations in current understanding, including the energy requirements for antimatter production and the unresolved nature of detecting antimatter in the universe.
This discussion may be of interest to those exploring advanced energy sources, particle physics, and the theoretical implications of antimatter in scientific research.
Simfish
I'm guessing that the amount of energy taken to generate an antimatter particle would always be more than what you would get back by colliding the antimatter generated with a matter particle.
But if we ever find a source of antimatter in the universe, then do you suppose that in the far future, we could utilize antimatter for power?
-T_Simfish
Im not an expert and don't quote me, but I think that the law of conservation of energy plays a part. I think the energy neede to convert a particle into a particle-antiparticle pair is the same as when the pair reunite to form energy.
To answer your second question, the problem with antiparticles is containig them, it is soo hard to contain them, you must use strong magnetic fields. To utalize it for use, I'd say it would take us another meillenium to get there.
Ah, ok. I forgot about the conservation of energy! Thanks for the response! :)
Maybe for spacecraft s but that's about it. You need to create the actual anti-matter first which raises the question, where do you get the energy to create the anti-matter?
where do you get the energy to create the anti-matter?/quote]
And that would have to come only with fusion power plants since antimatter takes up so much energy.
hmm... this sounds rather like somerthing from dan brown's Angels and Demons
It will cost a lot of money to produce antimatter... so if there is a new and more efficient way of producing - then maybe we can use it for spacecraft s.
Anti matter is already created in small quantities in large particle accelerators today, albeit very small quantities. Anti matter would most likely not be used for power generation, but power storage, as its energy density is about as high as possible.
And we already have the ability to store it, at least for relatively small periods of time.
Anti matter is most commonly produced through pair production. When a photon of light has enough energy, it will produce an electron/positron pair. The equation for this is:
[tex]E_{photon} = mc^2 + mc^2 + E_k[/tex]
the two m's are for the masses of the electron/positron, which are the same. And the [tex]E_k[/tex] is the left over kinetic energy as the electron/positron fly apart.
The energy of the photon can be wrotten as:
[tex]E = hf = \frac{hc}{\lambda}[/tex]
making out final equatin for pair production or antimatter/matter production:
[tex]\frac{hc}{\lambda} = mc^2 + mc^2 + E_k[/tex]
The rest mass energy of the electron is .511MeV, in order for electron-positron pair production to be possible, the photon must have an energy of 2(.511) = 1.022MeV. That is the threashhold for creating the pair, and if the energy of the photon is greater than the threashhold, then it adds on to the kinetic energy of the electron and positron after the transformation.
This website should clear everything up for you
http://hyperphysics.phy-astr.gsu.edu/hbase/particles/lepton.html
You are guessing very right, in fact, if you combined ALL the antimatter ever made at CERN, and if you used that antimatter by anihhilating it with matter, it would give off enough energy to light a light bulb for 3 seconds.
We probably won't ever use antimatter as a source of energy, I agree with Nenad about how its very hard to contain since it will want to annihilate with its counterpart. The conservation of energy would mean that the energy of the particles when they collide will equal the energy of the annihilation of the antiparticles and particles produced - this is what Nenad was implying. BUT! it also takes a lot energy to create strong magnetic fields in order to accelerate those particles to have such high energy. So...in the long run, you are losing much much more energy than gaining. It is theorized that there are still consentrations of antimatter in the universe left over from the Big Bang, which would give a very sufficial amount of antimatter, but once again, it would be a problem containing it. Although the biggest problem would be geting to it since it will be somewhere very far away from us.
we cannot tell where antimatter is. It will look exackly like matter, not difference but the only diff will be charge. And by the time we find this charge, we will be long gone in a fantastic explosion. For all we know, the Andrometa galaxy could be antimatter.
using anitmatter as energy, isn't simmliar to nuclear power which we already have?
Somewhat, yes - and using it to generate power would be trivially simple (simpler even than nuclear power). Collecting it (if we ever found a source) and containing it would be the tough part.
Are you saying that the speed in which matter and anti-matter collide, would affect the energy given?
I don't know much about this, so this may seem like a really really stupid question... but: So, you're saying when a matter particle and an anti-matter particle collide, they can create a very small amount of energy? I mean, just as much as a photon in the same direction?
Thats very true, which is why scientists are trying to detect heavy anti-atoms coming from deep space, possibly left over after the death of anti-stars in anti-galaxies. The Andromeda is probabaly not made from antimatter since its so close, we would expect anti-galaxies to be much much further, but your right it is possible.
No, in particle accelerators, particles (proton, neutrons, electrons) are accelerated to almost the speed of light, and then smashed into a target. That smash gives off so much energy that a particle-antiparticle pair are spontaneously produced. I was saying that the energy released from the smash would equal the energy that would be released if the particle and antiparticle were to annihilate each other after creation. They don't have to collide at high speed in order to annihilate, they just have to "touch". Although if they annihilated after colliding at some speed, that adds on to the energy released afterward.
Ahh, I see. Thanks =)
I think there must be something else involved, otherwise we would never see photons with more energy than that required to produce an electron-positron pair. Not to mention that if something else were not involved it would falsify a pet theory of mine :smile:
Keep on chuggin !
Vern
the photon creates the electron/positron pair, not the other way around. When the photon has enough energy (usualy gamma rays > 1.1MeV) Then an electron/positron pair is formed, and almost instantaineously anniahlated.
Keep on chuggin !
Vern
Yes there is something else involved. Pair production depends on temperatude. If the temperature is <[tex]10^{9} K[/tex], then no pair production occurs. If the temp is between [tex]6*10^{9} K\ to\ 10^{13} K[/tex] then an electron/positron pair is produced, and if temp is greater than the upper limit, a proton and a antiproton is produced.
Photons have temperture?
Not exactly, but photons have energy and temperature is a measure of energy. Thus, you can tell the temperature of an object by the color of the light it throws off.
I think I get your drift, but the way this is worded can be confusing. When you say "the temperature", I think people could take this to mean "the ambient temperature", which is not right. The determining factor as to whether pair production is "go-or-no-go" is the photon energy. If it is at least as large as 2mc2 (where m is the mass of the particle in question) in the lab frame, then you can produce a pair, no matter what the ambient temperature is.
I mean surrounding temp, not temp of a photon.
Oh yes, and as to the original question, consider the following numerical data.
From a single e+e- annihilation, you get about 1 MeV of energy (from the masses of the two particles). Compare that with the 200 MeV you get for the fission of every 235U nucleus. Then once you consider that the uranium is available by the kilogram, and positrons are so difficult to store en masse, and you've got quite an engineering problem on your hands. In that respect, the situation would have something in common with fusion power generation: We understand the physics just fine, but we can't get the technology to cooperate with what we know.
In that case, what you wrote is not correct. Pairs can be produced in deep space, where the average temperature is about 3 Kelvin.
heres a link, scroll down to pair production. Youll see what I mean: http://instruct1.cit.cornell.edu/courses/astro101/lec32.htm
OK, I see. The link is discussing the early universe in which there is a "sea" of photons. In an environment in which the universe is awash in radiation, the energy of the radiation field determines the ambient temperature. So in that case, there is a correletion between temperature and pair production. But in a way this hides the real quantity that determines the thresholds for pair production, and that quantity is photon energy.
Today, the universe is awash in weak radiation (with a temp of about 3K, as I said). As is known from QFT and from experiment, pair production is a quantum phenomenon, and as such it only takes a single photon to produce a pair in the Coulomb field of a heavy nucleus. It is the energy of this single photon that determines the thresholds for pair production, and it does not matter what the surrounding temperature is.
Im just stationg what the site says. I trust Cornell, theyre a good university. But you do have a point.
To be sure, Cornell is trustworthy. But that site is meant to be a layperson's introduction to the early universe, not a tutorial on particle physics.
  • · Replies 18 ·
  • · Replies 26 ·
  • · Replies 34 ·
