Is the distance relative also?
  • Context: Graduate
  • Thread starter Thread starter xponential
    Relative
The discussion revolves around the concept of distance in the context of special relativity, particularly whether distance is also relative like time. Participants explore scenarios involving a spaceship moving at relativistic speeds and how distance measurements may differ based on the observer's frame of reference.
  • One participant describes a scenario involving two synchronized watches, one on a spaceship and one on Earth, to illustrate time dilation and questions if a similar effect applies to distance.
  • Another participant asserts that the distance reading on a device in the spaceship will be less than the calculated distance based on the number of orbits, citing the definition of velocity.
  • A participant presents two scenarios: one involving a relativistic train passing rail ties and measuring distance, and another using RADAR to measure distance to a destination at speed, questioning which measurement should be reported.
  • In response to the scenarios, another participant suggests that the shorter value should be reported in the log book, indicating a preference for the relativistic measurement.
Participants express differing views on how distance is measured in relativistic contexts, with no consensus reached on the implications of these measurements.
The discussion includes assumptions about the functioning of distance-measuring devices in relativistic scenarios and the implications of different measurement methods, which remain unresolved.
xponential
From the special theory of relativity, I understand that time is not absolute but relative according to the speed of observer. For instance, suppose there are two watches, one put inside a spaceship which rotates the Earth and the other is just stationed on Earth and both of them are synchronized firstly to have the same time reading. Let's consider now that the spaceship rotated the Earth 100 times at half the speed of light and then stopped. Then, if we looked at the current time readings on both watches, they will be significantly different.
Is that also applied to distance? If there is a device in the spaceship which tells to those inside it how much distance (in km) the ship has been moving so far (like the one in the car), and after the ship was stopped, will the reading of the device be different (i.e. much less) than if we got the length of the spaceship's path around the Earth and multiplied it by 100 (since there were 100 rotations)?
Thanks for your interest.
Welcome to PF!
Of course. It will show ship time * 0.5*c, that's the definition of velocity. This is less than 100 orbits as seen from earth.
How does such a device work?
You can't watch the space go by.
Scenario 1: if you have a relativistic train and you count the number of rail ties that you pass, you will get the same number as the observer at the station. However, if you examine them through a trapdoor in the bottom of the train, you will measure them to be closer together. If you use the shorter span as your basis, then sure you saw a shorter distance in your voyage.
Scenario 2: at speed, you use RADAR to find the range to your destination. You find a much shorter distance than you did when you measured it before starting out. At the end of the journey, which value to you report in your log book?
I think it should be, then, the shorter value.
JDługosz & Ich, thank you very much for the clarification.
  • · Replies 65 ·
14K
  • · Replies 47 ·
  • · Replies 36 ·
  • · Replies 31 ·
  • · Replies 90 ·
  • · Replies 19 ·
  • · Replies 24 ·
  • · Replies 18 ·
  • · Replies 98 ·
10K
