Momentum of a vertical stream of water hitting a surface
The discussion focuses on the momentum artefact created when a vertical stream of water from a bottle impacts a surface, affecting the measured flow rate. The user investigates how the height of the bottle influences the size of this artefact, hypothesizing a relationship where the area under the flow rate spike increases with the square root of the height. Key equations referenced include the acceleration due to gravity (g = 9.81 m/s²) and the relationship between force, momentum, and flow rate. The user seeks to model this relationship mathematically to better understand the dynamics involved.
  • Understanding of basic physics concepts such as momentum and force
  • Familiarity with flow rate measurement techniques
  • Knowledge of graphing data and interpreting curves
  • Basic calculus for modeling relationships
  • Research the principles of fluid dynamics and momentum transfer
  • Learn about graphing techniques to analyze flow rate data
  • Explore mathematical modeling of physical phenomena
  • Investigate the effects of height on fluid impact forces
Students in physics or engineering, researchers studying fluid dynamics, and anyone interested in experimental measurement techniques related to fluid flow.
velvet
Hello there, I have a question, I wonder if you can help me.
I am using scales to measure the volume of liquid coming from a bottle, and then differentiating this volume to give flow rate. The bottle emits a constant flow rate and I hold it so that the stream falls vertically, collecting in a jug on the scales. When the stream of liquid initially hits the scales, it creates a momentum artefact, i.e. a 'spike' in the flow rate which then settles down to the correct flow rate. Obviously this spike also appears at the end of the flow, but this time negative.
I am investigating the size of this artefact when the bottle is held at different heights from the scales, and if it can be modeled. I would like to come up with an equation to describe the relationship but I am not sure how to go about this.
Acceleration due to gravity, g = 9.81 metres per second squared
Force = rate of change of momentum
Momentum = mass x velocity
Flow rate from bottle = constant
1litre = 1kg
I have poured the water from several different heights, and calculated the area under the flow rate 'spike', i.e. the volume artefact. The area under the artefact seems to increase with the square root of the height. (It looks like that sort of relationship but I am not sure. I believe if I plotted 'height of bottle' against 'area under artefact', the curve would tend towards becoming flat, which a height curve does not.)
I think my problem is that the volume of water in the jug is constantly changing so I am not sure which mass to use in the calculations.
Many thanks :)
How dramatic is the spike? Maybe you could get a graph and post a jpg file of what you're seeing. My hypothesis is that when you first hit the scale you are seeing some recoil from the first drops that hit the scale, which gives you more then a factor of 1, but less than a factor of two, for the change in momentum that translates to force. Once you have more liquid on the scale, the substance is no longer recoiling because of the liquids cohesion.
Hello, thank you for your reply.
This graph shows the flow rate curves, the curve on the left is with the bottle held closest to the scales and that on the right, the farthest away (those that don't increase are anomolies because I have done it again more carefully since and with repeats):
http://i119.photobucket.com/albums/o158/alisonbray/Flowratevtime.png
This graph shows the relation between area under spike (volume artefact) and distance between bottle nozzle and impact surface:
http://i119.photobucket.com/albums/o158/alisonbray/Heightvartefact.png
Many thanks :)
  • · Replies 30 ·
  • · Replies 32 ·
  • · Replies 56 ·
