Time reversal symmetry breaking in EM
The discussion centers on the issue of time reversal symmetry breaking in electromagnetic (EM) fields, particularly when analyzing solutions derived from Liendard-Wiechert potentials. It is established that under time reversal, the electric field remains unchanged while the magnetic field reverses its sign. However, the application of these principles to the retarded Green's function leads to inconsistencies, as the electric field does not maintain symmetry when time is reversed. The conversation suggests that this discrepancy may stem from the choice of retarded solutions, which Einstein critiqued for imposing time-asymmetry.
  • Understanding of electromagnetic theory, specifically Maxwell's equations.
  • Familiarity with Liendard-Wiechert potentials and their applications.
  • Knowledge of Green's functions in the context of differential equations.
  • Basic principles of special relativity and time symmetry.
  • Explore the implications of the retarded Green's function in electromagnetic theory.
  • Investigate Einstein's views on advanced and retarded solutions in the context of time symmetry.
  • Study the mathematical derivation of Liendard-Wiechert potentials and their physical interpretations.
  • Examine the role of relativistic effects in electromagnetic field behavior under time reversal.
Physicists, particularly those specializing in electromagnetism and relativity, as well as researchers exploring the foundations of time symmetry in physical theories.
kcdodd
I have come across a problem I am trying to understand, and hoping someone here has some insight. Basically, when writing down different solutions for an EM field from given sources, there seems to be a problem from the standpoint of time symmetry. From my understanding, if you reverse time, the electric field should remain unchanged, and the magnetic field should have the same magnitude but opposite sign. You can see that must be true by several methods (ie just looking at the force on other particles), but fails here:
For instance, from Liendard-Wiechert potentials:
[tex]\vec{E} = \frac{q(\hat{r} - \vec{\beta})}{\gamma^2(1-\vec{\beta}\cdot\hat{r})^3R^2}\bigg|_{ret}[/tex]
(assuming uniform motion)
if you reverse time beta changes sign and so E here clearly may not necessarily obey the symmetry.
Also, if you assume
[tex]\vec{B} = \hat{r}\times\vec{E}[/tex]
neither does B.
Perhaps this is a relativistic effect, if someone knows how to resolve it.
I think the problem is to do with the choice of a retarded Green's function and hence retarted time solutions. Einstein apparently believed that choosing retarted solutions meant imposing time-asymmetry by hand and preferred a half-retarded half-advanced solution instead.
