Derivatives and fractions (relationship?)
The discussion revolves around the relationship between derivatives and fractions, particularly in the context of calculus. Participants explore the conceptual similarities and differences between derivatives, as expressed in Leibniz notation, and fractions, touching on topics such as the chain rule and the properties of differential operators.
  • One participant notes that while derivatives are different from fractions, there are similarities, particularly in the context of the chain rule.
  • Another participant emphasizes that the notation df(x)/dx represents an operator, suggesting that derivatives may have properties akin to algebraic structures.
  • A later reply clarifies that dy/dx is not a fraction, but it can often be treated like one because it represents the limit of a fraction.
  • One participant provides examples illustrating that while derivatives cannot be manipulated as fractions in all cases, they can be treated as such under certain conditions, particularly when considering limits.
  • There is a discussion about the necessity of defining differentials separately to facilitate the use of Leibniz notation in calculus.
Participants express differing views on the nature of derivatives and their relationship to fractions. Some agree on the utility of treating derivatives like fractions in certain contexts, while others emphasize the fundamental differences between the two concepts. The discussion remains unresolved regarding the extent to which derivatives can be considered analogous to fractions.
Participants acknowledge limitations in their understanding and the complexity of the concepts involved, particularly regarding the manipulation of derivatives and the application of limits.
phy666
learning calculus here. got differential calculus, though it is a little foggy, and most of integral calculus, which is a little foggier. also using very unpolished precalc background, though i did give most of it a once-over. i have many questions which i can't think of, but of the top of my head...
when learning leibniz notation it is pointed out that derivatives are different than fractions. However, some similarities, such as the chain rule, point to an obvious relationship. would someone please explain this relationship? compare/contrast? If I had to guess I would say that a derivative, being a quantification (of a function at a certain point), is something like a number, in the same way that a fraction is, and thus(?) owning an analogous internal composition. Does that mean derivatives are subject to algebraic field properties if arithmetic operators are applied? sorry just typing random words here...
Slow down - one thing at a time.
You speaking of the df(x)/dx ? Correct? In which case, it is an operator. You are stating take the derivative of f(x) with respect to x. After that, not quite sure. No differential operator is more like a ring I believe.
Yes, it is true that [itex]dy/dx[/itex] is NOT a fraction. It is, however, the limit of a fraction so can often be treated like a fraction. For example, it is true that if y= f(x) and [itex]x= f^{-1}(y)[/itex], then
[tex]\frac{dx}{dy}= \frac{1}{\frac{dy}{dx}}[/tex]
You cannot prove that by just turning over the "fraction" in the denominator but you can go back before the limit in "[itex]\lim_{h\to 0} (f(x+h)- f(x)}{h}[/tex]", inverting <b>that</b> fraction and and taking the limit again.<br /> <br /> Similarly, we cannot prove the chain rule: <br /> [tex]\frac{df}{dx}= \frac{df}{du}\frac{du}{dx}[/tex]<br /> by "cancelling" the "du"s but we can go back before the limit, cancel and then take the limit again.<br /> <br /> That is one reason for the Leibniz notation and for then defining the "differentials" dx and dy separately- so that we <b>can</b> use the fact that, while a derivative is not a fraction, it can be <b>treated like one</b>.[/itex]
  • · Replies 17 ·
