Solving f(x) Inverse: x^2-4x, x∈R, |x|≤1
  • Thread starter Thread starter thereddevils
    Function
The discussion revolves around finding the inverse of the function f(x) = x^2 - 4x, with the constraint that x is a real number and |x| ≤ 1. Participants are exploring the implications of the function being one-to-one within the specified domain and the resulting behavior of its inverse.
  • Participants discuss the calculation of the inverse and the confusion arising from the multiple outputs for a single input. They question how the restricted domain affects the one-to-one nature of the function and the selection of the appropriate branch for the inverse.
The discussion is active, with participants providing insights on the implications of the domain and range of the function. Some guidance has been offered regarding the use of the domain to determine the correct branch of the inverse function, but there remains some uncertainty about the relationship between the function's range and the inverse's domain.
Participants note that the function is one-to-one within the domain |x| ≤ 1, but question how this affects the inverse when considering the broader context of the function's behavior over all real numbers. There is also mention of the range of f being between -3 and 5, which is relevant to understanding the domain of f^(-1).
thereddevils
Given [tex]f(x)=x^2-4x[/tex] , [tex]x\in R[/tex] , [tex]|x|\leq 1[/tex]
so f(x) is a one to one function , and i am supposed to find its inverse .
and i found :
[tex]f^{-1}(x)=2\pm \sqrt{4+x}[/tex]
this is weird since a single input would give 2 different outputs and it can't be considered a function . But f(x) is a one-one function , so it should have an inverse ?
You have solved the equation [itex]y=x^2-4x[/tex] for all x in R. Yet the original function only exist for |x|<=1. This restricts the domain such that it is one to one (it is not one to one for all x in R). Use this domain to determine which branch you need.[/itex]
[itex] <br /> thanks ,i thought so too but i am not sure how to see from the domain that the inverse should be 2+root(4+x) OR 2-root(4+x)[/itex]
The domain of f is {x | |x| <= 1}. That domain can be written as an interval, which should help you figure out which branch to use for the inverse.
The range of f is the domain of f^-1. If f(a)=b then f^-1(b)=a.
thanks again !
so the domain of f(x) is between 1 and -1 , and the range is between -3 and 5 , so the domain of f^(-1)(x) is also between -3 and 5 ? so both +ve and -ve would produce such range , err i am still confused ,
I suggest you plug in some numbers to see what happens.
thanks !
Broadening things out, it depends on what you mean by one-to-one. The term one-to-one means injective to some, bijective to others. The function is a one-to-one function by both meanings of the term over the domain |x|≤1. It is not bijective over all of the reals, so it does not have an inverse function for this extended domain. (It does however have an inverse multivalued function.)
  • · Replies 21 ·
