Maths or physics Interception question
  • Thread starter Thread starter High_flier
    Physics
The interception question involves two aircraft flying towards each other from airports A and B, which are 200 nautical miles apart. Aircraft 1 departs from airport A at 100 knots, while Aircraft 2 departs from airport B at 200 knots. By applying the formula Distance = Rate x Time, it is determined that both aircraft will pass each other 230.16 nautical miles from airport A after 2 hours of flight. This solution illustrates the proportional relationship between speed and distance traveled by each aircraft.
  • Understanding of basic physics concepts, specifically motion and speed.
  • Familiarity with nautical miles and knots as units of measurement.
  • Ability to solve linear equations and apply algebraic principles.
  • Knowledge of the formula Distance = Rate x Time.
  • Study the principles of relative motion in physics.
  • Learn how to convert between different units of speed, such as knots to nautical miles per hour.
  • Explore more complex interception problems involving multiple variables.
  • Practice solving real-world navigation problems using similar equations.
Aerospace engineers, pilots, students studying physics or mathematics, and anyone interested in navigation and flight dynamics will benefit from this discussion.
High_flier
Two airports (A and B) are 200nm apart. Aircraft 1 leaves airport A and
flies to B at 100kts. Aircraft 2 leaves airport B and flies to A at 200kts.
Both aircraft leave at the same time, where relative to airport A will they
pass each other?
nm=nautical miles
kts=kts
Here's one way to solve this. Call the time at which they pass each other t. During that time, each flies a certain distance D = V t. So aircraft 1 travels a distance [itex]D_1 = V_1 t[/itex] and aircraft 2 travels a distance [itex]D_2 = V_2 t[/itex]. But the total distance traveled by both aircraft must equal the distance between A and B (200 nm). I'll leave the next step to you: set up the equation and solve for t, then plug t into solve for [itex]D_1[/itex].
Once you understand what's happening, you can practically do this problem in your head. Realize that the distance each aircraft travels is proportional to its speed. Aircraft 1 travels half as fast as aircraft 2, so it travels half the distance of aircraft 2. If aircraft 1 travels D, aircraft 2 travels 2D. The total is 3D = 200 nm. Solve for D.
In order to solve this interception question, we need to use the formula: Distance = Rate x Time.
First, let's convert the speeds to nautical miles per hour (nmph) since the distance is given in nautical miles.
100 kts = 115.08 nmph
200 kts = 230.15 nmph
Next, we can set up a table to represent the distance each aircraft covers in a certain amount of time:
| Aircraft | Rate (nmph) | Time (hours) | Distance (nm) |
| 1 | 115.08 | x | 115.08x |
| 2 | 230.15 | x | 230.15x |
Since both aircrafts leave at the same time, we can set the times equal to each other:
115.08x = 230.15x
Solving for x, we get x = 2.
This means that after 2 hours, both aircrafts will have traveled a certain distance and will pass each other.
To find out where they will pass each other relative to airport A, we can plug in x = 2 into the distance formula:
Aircraft 1: 115.08 x 2 = 230.16 nm
Aircraft 2: 230.15 x 2 = 460.3 nm
Therefore, they will pass each other 230.16 nm from airport A.
In conclusion, after 2 hours, both aircrafts will pass each other 230.16 nm from airport A.
16K
