Calc. the deformation of a cable on a reel
  • Thread starter Thread starter ihaland
    Cable Deformation
This discussion focuses on calculating the deformation of a steel cable placed on a reel with an outer diameter (OD) of 3.51 meters. Key considerations include the cable's cross-sectional area (CSA), whether it is solid or stranded, and the number of strands if it is stranded. Additionally, the discussion highlights the importance of understanding both standard engineering properties and potential degradation due to environmental conditions and curvature effects on the cable's performance.
  • Understanding of cable mechanics and deformation principles
  • Knowledge of material properties related to steel cables
  • Familiarity with cross-sectional area calculations
  • Awareness of environmental factors affecting cable performance
  • Research the calculation methods for cable deformation under load
  • Explore the properties of stranded vs. solid steel cables
  • Investigate the impact of curvature on cable performance
  • Learn about environmental degradation factors affecting steel cables
Engineers, material scientists, and professionals involved in cable design and application, particularly those focused on mechanical properties and environmental impacts on steel cables.
ihaland
I want to see what effects placing a steel cable on a reel of size of OD 3,51 m will have on the properties of the material?
How will I go about doing this?
A appreciate any help I can get :-)
What is the cross-sectional area (csa) of the cable? Is it solid or stranded? If stranded, how many strands? What properties are you interested in? Of course you will think of the usual engineering properties that books and manufacturers like to tell you, but there are also property changes like degradation arising from the conditions in which the cable reel is kept...quite apart from the curvature which is probably what is bothering you.
  • · Replies 17 ·
