Dynamics Newton's 2nd Law and Forces of Friction
The discussion centers on applying Newton's Second Law to a system of two blocks, A and B, with static and kinetic friction coefficients of μ_s=0.4 and μ_k=0.3, respectively. The applied force P=6 lb leads to confusion regarding the acceleration of Block A, which does not slide over Block B due to static friction. Participants clarify that the correct approach is to treat the blocks as a single system when calculating acceleration, ensuring that the internal friction force is not incorrectly assumed to equal the applied force. The conclusion emphasizes the importance of accurately applying Newton's Second Law and understanding the role of static friction in the system.
  • Understanding of Newton's Second Law of Motion
  • Knowledge of static and kinetic friction coefficients
  • Ability to create and interpret free body diagrams
  • Familiarity with basic concepts of mass and force in physics
  • Study the implications of static versus kinetic friction in mechanical systems
  • Learn how to construct and analyze free body diagrams for multi-body systems
  • Explore the application of Newton's Laws in different friction scenarios
  • Investigate the relationship between mass, weight, and acceleration in physics problems
This discussion is beneficial for physics students, educators, and anyone interested in understanding the dynamics of forces, particularly in systems involving friction and multiple bodies. It is especially relevant for those studying mechanics or preparing for physics examinations.
DMBdyn
Block B rests upon a smoot surface. If the coefficients of static and kinetic friction between A and B are mu_s=0.4 and mu_k=0.3, respectively, determine the acceleration of each block if P=6lb. (picture attached below)
Using Newton's Second Law,
[tex]\sum[/tex]Fx=max
[tex]\sum[/tex]Fy=may
My free body diagram is in the picture attached below along with values for all variables.
First I sum for the forces in the x-direction.
Because the force of static friction is greater than the force applied to Block A, I assume the force of static friction to reach a value equivalent to the applied force. I take this to mean that Block A is 'stuck', and will not move across the top of Block B.
Newton's 2nd Law applied to Block A:
[tex]\sum[/tex]Fx=mAaxA=P-Ff=6-6=0
Block B is different, as it experiences an equal but opposite force of friction in the positive x-direction. I determine the acceleration of the system from the sum of the forces in the x-direction for Block B (ie. I cannot get a valid answer for the acceleration of Block B using Newton's Second Law unless I assume it's mass to be the sum of both masses).
Newton's 2nd Law applied to Block B:
[tex]\sum[/tex]Fx=(mA+mB)axB=Ff=6
Therefore,
ax,sys=P/(mA+mB)
I'm pretty sure this is correct. However, I'm not sure about my methodology, and I'm also a bit shaky on my conceptual understanding of the problem.
First of all, I'm having a hard time rationalizing the fact that Newton's Second Law tells me Block A experiences no acceleration, when it in fact does experience acceleration. My theory is that my sum of the forces for Block A must be telling me that Block A will not slide over Block B, just as if it were on the ground, it would not slide over the ground. However, Newton's Third Law tells me that there will be an equal and opposite friction force that Block B will experience. At this point, it seems I have two options, 1) Since I know that Block A will not move across Block B, I apply Newton's Second Law to the entire system, or 2) I apply Newton's Second Law to Block B, but substitute the mass of the system for the mass of Block B (using the value of 6 lb for the force of friction, since I have assumed the static force of friction will not exceed the applied force).
Option 1 makes sense to an extent, but Option 2 makes no sense. It doesn't seem to be correct to substitute the mass of the system for the mass of Block B; however, if I don't, I don't think I will get the right answer. Furthermore, option 1 makes sense in that if Block A is not going to move over Block B, then Block B must be moving with Block A, thus I can apply Newton's Second Law to the system to obtain the answer.
Basically, I understand that the top block is not slipping, thus the whole system moves according to Newton's Second Law. However, looking at the free body diagram for the second block yields a phenomenon I cannot explain, since Newton's Second Law has a 6lb force acting on the block, which would give a different acceleration for the bottom block than the acceleration I get for the system.
If clarification is needed just let me know. I'll be glad to accommodate.
this is your major error. The force of static friction is less than or equal to u_s(N).
Ff is not 6
yes, correct
Bad assumption...the mass of Block B is what it is
Therefore,
ax,sys=P/(mA+mB)
You seem to be applying Newton 2 to the system assuming the blocks are moving together with the same acceleration (A stuck to B), in which case the force applied to the system is P, not Ff.
It is accelerating...Newton 2 is not telling you differently, you are telling yourself that
good
no good
You are correct that it makes no sense, so don't make assumptions to 'fudge' the right answer
yes
Due to your initial error, the internal force acting on B is not 6, it is Ff
Your observations are good...assume the blocks move together and apply Newton 2 to the system to find a, then draw free body diagram of A to find Ff and give it a sanity check to confirm they are moving together...draw a FBD of B to check your work...don't forget to use the corrrect value for the masses, in slugs...
  • · Replies 20 ·
