Efficient Testing Methods for Centrifugal Blowers - Tips and Tricks
  • Thread starter Thread starter maxx_payne
    Centrifugal
The discussion revolves around methods for testing centrifugal blowers, focusing on various parameters such as head, flow, and efficiency. Participants share insights on testing procedures and resources for further information on blowers.
  • Homework-related
  • One participant inquires about the specific aspects of centrifugal blowers that need testing, such as head, flow, and efficiency.
  • Another participant suggests a testing method involving connecting the blower to a motor, measuring pressure and temperature, and calculating efficiency based on power output.
  • Several participants express a need for additional resources and information about blowers, with suggestions including textbooks on Applied Fluid Mechanics and turbomachinery.
  • A participant mentions the existence of a standard for blower testing, specifically the Performance Test Code (PTC) 10, which outlines methods for measuring blower performance.
Participants generally agree on the importance of measuring specific parameters for testing blowers and share various methods and resources. However, there is no consensus on a singular approach or definitive resource for testing methods.
Some discussions involve assumptions about the knowledge level of participants and the applicability of certain resources to centrifugal blowers versus other types of compressors.
Individuals interested in testing methods for centrifugal blowers, including engineers, students in mechanical or aerospace engineering, and professionals in fluid mechanics.
maxx_payne
centrifugal blower ?
how can i test a centrifugal blower ?
eeeeeeeeeeeeeh no answers ?
What do you want to test it for, head, flow, efficiency what does it blow and what does it do with the fluid that it blows?
With a question that simple, here is a simple answer:
- You connect it to a motor of known power output.
-You measure the pressure and temperature at inlet and outlet, and the mass flow rate.
- From those numbers, you calculate the actual power done on the fluid.
- Divide the actual power done on the fluid by the known shaft power to obtain the efficiency of the unit.
- Repeat for different rpm, throughout the rpm range.
thanx for your very simple answer :D
can u tell me i need more information about blowers where can i get it ?
A textbook on Applied Fluid Mechanics or similar will have a section on blowers.
CS
Basic info can be obtain on this http://www.turbobygarrett.com/turbobygarrett/tech_center/turbo_tech103.html?" . It's about turbos, but the compressor of a turbo is a centrifugal compressor which is connected to a turbine instead of the crankshaft. So what applies to one, applies to the other.
For more detailed info on their designs, you need a book about turbomachinery similar to this http://books.google.ca/books?id=s4Q...resnum=3&ved=0CDgQ6AEwAg#v=onepage&q&f=false".
There is a standard for blower testing: Performance Test Code (PTC) 10. It provides a standard method to measure a blower head / flow curve.
  • · Replies 22 ·
  • · Replies 16 ·
12K
  • · Replies 16 ·
12K
  • · Replies 20 ·
  • · Replies 92 ·
11K
