How Does Projectile Motion Relate to Speed and Distance Graphs?
The discussion focuses on the relationship between projectile motion and the corresponding speed and distance graphs derived from a practical experiment involving a ball rolling down a slope. The participant analyzed three graphs: speed vs. time, vertical distance vs. time, and distance vs. time squared. The key equations referenced include v = u + at and s = ut + 0.5at², with the participant confirming that speed is proportional to time and that distance increases quadratically with time. Clarifications were provided regarding the nature of the graphs, emphasizing that the vertical distance vs. time graph does not represent an exponential relationship.
  • Understanding of basic kinematics, including velocity and acceleration.
  • Familiarity with the equations of motion, specifically v = u + at and s = ut + 0.5at².
  • Knowledge of graph interpretation, particularly linear and quadratic relationships.
  • Basic algebra skills for manipulating equations and understanding proportional relationships.
  • Study the effects of incline angles on acceleration in projectile motion experiments.
  • Explore the derivation and application of the equations of motion in different contexts.
  • Learn about graphing techniques for analyzing motion, including the significance of slope and curvature.
  • Investigate the differences between linear and non-linear relationships in physics graphs.
Students studying physics, educators teaching kinematics, and anyone interested in understanding the principles of projectile motion and graph analysis.
Zel
I did a practicle to show the path of a projectile by rolling a ball down a slope. The graph produced was exponential. The time (tics, time intervals), vertical distance (from starting position) and speed (distance/time) were calculated.
1. Draw a graph of speed vs time (time on x, speed on y)
It produced a straight line. It then asked what this indicates about projectile motion, and how does it correlate with the equations used for projectile motion.
I said that v is proportional to t, as when time increases, so does velocity. I used the equation v = u + at, where u = 0, and a can be gravity, so v = 9.8t ... so v increases at a constant rate. Would this be correct?
2. Draw the graph of vertical distance vs time (time on x, distance on y). It produced an exponential, with the curve increasing upwards as x increases.It then asked what this indicates about projectile motion, and how does it correlate with the equations used for projectile motion.
I said that d is inversely proportional to t, as when t increases, d does in a non-linear fashion. I need help finding an equation for this though.
3. Draw a graph of distance vs t^2 (t^2 on x, d on y). It produced a straight line. It asks to explain the meaning of the graph, so i used s=ut+0.5at^2, u = 0, so s = at^2, so as time increases, so does distance... would this be correct?
Any help or advice given would be GREATLY appreciated
Thanks in advance
Welcome to Physics Forums.
Pretty much, though if the object was rolling down an incline then a won't be 9.8 m/s2. You can figure out what a is by getting the slope of the v-vs-t graph.
You already have the equation, it's the "s=ut+0.5at^2" that you give below. Note, this is neither an exponential nor an inverse proportion, but it is a type of equation you would have studied in algebra.
It's correct, but your teacher might be looking for more than that. I'm a little puzzled by the phrase "explain the meaning of the graph", is that the exact wording of the question?
  • · Replies 18 ·
