Solving 1 + 2cos(2x+ π/3) for Zeroes: Step-by-Step Guide
  • Thread starter Thread starter jasper10
The original poster seeks to find the zeroes of the function f(x) = 1 + 2cos(2x + π/3) within the range (0 ; π). They have identified one zero at x = π/6 but are uncertain about finding additional zeroes.
  • Participants discuss the transition from the equation 1 + 2cos(2x + π/3) = 0 to identifying zeroes, with some questioning the steps taken. There are suggestions to use the sum-of-angles formula and to explore the unit circle for additional solutions. Others express confusion about determining all angles where cos(y) = -1/2.
The discussion is ongoing, with participants providing insights into the unit circle and the properties of cosine. Some have offered guidance on how to visualize the problem and identify potential solutions, while others are still clarifying their understanding of the concepts involved.
Participants note the restriction of x to the interval (0, π) and discuss the implications of this constraint on finding valid solutions. There is also mention of the need to consider multiple angles where cos(y) = -1/2, as well as the potential complexity introduced by the sum-of-angles formula.
jasper10
Find the zeroes of
f(x) = 1 + 2cos(2x+ π/3)
Range: (0 ; π)
hence, cos(2x + π/3) = -1/2
hence, 2x + π/3 = 2π/3
and, x = π/6 which is 30 degrees
can someone help me find the other 0 ?
I don't know how to!
Thanks a lot!
(the answer is x=π/2 but i don't know how to get there!)
First, I don't quite know how you went from your first step to your second, even though it does turn out to be correct. A bit of explanation would be most appreciated.
Second, have you tried using the sum-of-angles formula to expand your cosine out? It might make it easier, I think...
Ok Char. Limit,
I edited my answer and showed the transition step.
What do you mean by "the sum of angles formula" ?
Well, if one looks at the unit circle, one can see that 2*pi / 3 is one place where
cos(y) = -1/2. However, there are more places on the unit circle in which
cos(y) = -1/2. Finally, one can also add 2*pi*n to the result, and end up at
the same place.
the same place.
But he restricted x to be between zero and pi...
The sum-of-angles formula is as follows:
[tex]cos(x+y)=cos(x)cos(y)-sin(x)sin(y)[/tex]
I have no idea how to prove it, but it is a theorem, I believe.
Yes, but still, one can manually inspect the formulas to see when
[tex] 2x + \pi /3 = 2\pi /3 +2\pi n[/tex]
, and after that see if x is inside the interval between 0 and pi.
cos(y) = -1/2.
Yes, my question ultimately is
How does one determine these other places where cos(y) = -1/2 ?
If you are familiar with the unit circle, you have that the x-coordinate on the circle
is cos(x), while the y-coordinate is sin(x). For a picture, please see
http://en.wikipedia.org/wiki/Unit_circle
In the picture, you can see that cos(x) = -1/2 means: at which place at the unit circle
is the x-coordinate equal to -1/2? And there are two places that can happen at in the circle. Does this help?
Well, wouldn't you just have to add pi/4 for the next zero and then 3pi/4 and keep going until you're beyond your range in this case? Since the function is pretty much a squashed together cos curve (twice as many zeros as a normal one) that is half it's amplitude up the y-axis, it's amplitude being 2, that is out of phase of your standard cos curve by pi/3. I'm not sure I'm visualising it right, but I guess you could always sketch it up on some spare sheet.
Correction: cos(y) = -1/2 for y = 2pi/3 or for y = 4pi/3.
Replace y by 2x + pi/3 and you should get two values of x in (0, pi).
It actually makes it much harder.
I stand corrected then.
Mark44 said:
cos(y) = -1/2 for y = 4pi/3 or for y = 5pi/3.
How do you know this?
Mark gave you the values where the cosine is -1/2 in the third quadrant and 1/2 in the fourth quadrant. You're interested in the values where cosine is -1/2, not 1/2.
The first thing you should do is draw a unit circle. Then sketch the places where the cosine is equal to -1/2 and find the appropriate angles. In which two quadrants does your solution lay?
How does one find the place where cosine is equal to -1/2?
and as you said, the solution is in the third quadrant and the first solution (Pi/6) is in the first.
Due to a mental lapse, one of the values I gave was incorrect. The values of y should have been in the second and third quadrants, but not in the fourth. I have corrected my earlier response.
No, [itex]\cos \pi/6=\frac{1}{2}\sqrt{3}[/itex]. Secondly I am not asking you to draw the position where cos is -1/2 in the unit circle exactly. The use in the unit circle is that you can see in which quadrant the solutions lay. When you draw a line radially outwards from the origin you can form a triangle. Which side of that triangle corresponds to the cosine and which one to the sine? To answer your question you want to know where that side of the triangle is -1/2.
There are just a handful of angles that you are expected to know exactly: 0, pi/6, pi/4, pi/3, pi/2, plus their complements and supplements. If you plot these angles in the unit circle, you can use symmetry to show that cos(y) = 1/2 for y = pi/3 and y = 5pi/3, and that cos(y) = -1/2 for y = 2pi/3 or y = 4pi/3.
Ok! thanks, i kind of get it now!
  • · Replies 17 ·
