How does one calculate his distance to the center?
  • Thread starter Thread starter moonman239
    Center
The discussion revolves around calculating the distance from an observer to the center of the Earth, considering both the Earth's shape and the observer's altitude. The subject area includes concepts related to geodesy and the geometry of ellipsoids.
  • Exploratory, Assumption checking
  • Participants explore the calculation of distance using mean radius estimates and question the assumptions regarding the Earth's shape and the provided values for radii. There is also a suggestion to visualize the problem for better understanding.
The discussion is ongoing, with some participants providing calculations based on different interpretations of the problem. There is no explicit consensus, but guidance has been offered regarding the use of mean radius and altitude in the calculations.
Participants note the lack of specific values for the semimajor and semiminor axes, which may affect the calculations. The original poster's altitude is also a factor in the discussion.
moonman239
Let's assume that an observer on a perfectly ellipsoidal Earth determines that his distance to the center of Earth is 6372 kilometers, not counting his altitude. If his altitude is 600 miles above mean sea level, then approximately how far is he in actuality from the center?
Hi Moonman 239, give my regards to the other 238! (Or however many there are; I guess more might have joined since you.)
As no values for the semimajor and semiminor axes are given in your question, I'll take the first and simplest kind of mean radius (mean sea level) estimate by the IUGG, International Union of Geodesy and Geophysics, from here ( http://en.wikipedia.org/wiki/Earth_radius#Mean_radii ), namely 6 371 km. I reckon your observer would be 6 371 km + (6 372 - 6 371) km + 966 km = 6 372 km + 966 km = 7 338 km from the centre. That is, the observer's radial distance not including their altitude, plus the difference between their radial distance and the mean, plus their altitude above the mean. Or, more simply, the observer's altitude above the mean plus the mean. Does that sound reasonable? If it doesn't make sense, try drawing a picture. Don't trust me though, I might have made a mistake, or misunderstood the question.
Equatorial radius = 6378.137 km
Polar radius = 6356.7523 km
Thanks for the answer.
  • · Replies 21 ·
  • · Replies 18 ·
