What is the direction of velocity when a particle hits the surface of the sea?
  • Thread starter Thread starter thereddevils
    Direction Velocity
The discussion focuses on determining the direction of the velocity of a particle projected from a cliff at a speed of 40 m/s and an angle of elevation of 45 degrees, hitting the sea 200 m horizontally away. The calculations involve horizontal motion using the equation s=vt, leading to a time of 5√2 seconds. For vertical motion, the final vertical velocity is calculated as v=40 sin 45 - 10(5√2), resulting in a vertical component of -60/√2 m/s. The direction of the velocity is found by combining the horizontal and vertical components to determine the angle of impact.
  • Understanding of projectile motion principles
  • Familiarity with trigonometric functions and their applications
  • Knowledge of kinematic equations for horizontal and vertical motion
  • Ability to calculate vector components and angles
  • Study the principles of projectile motion in detail
  • Learn how to derive the angle of impact using vector components
  • Practice problems involving kinematic equations in two dimensions
  • Explore advanced topics in physics such as trajectory analysis and air resistance
Students studying physics, particularly those focusing on mechanics and projectile motion, as well as educators looking for examples of problem-solving in kinematics.
thereddevils
A particle is projected from the top of a vertical cliff with a speed of 40 m/s at an angle of elevation of 45 degrees towatds the sea . The particle hits the surface of the sea at a point whose horizontal distance from the cliff is 200 m . Find the direction of the velocity of the particle when it hits the surface of the sea . [Take g=10 m/s^2]
For horizontal motion ,
s=vt
200=40 cos 45 t
t=5 root (2)
For vertical motion ,
v=u+at
v=40 sin 45 -10(5 root 2)
=-(60)/(root 2)
This is the magnitude and i hv no idea how to find its direction
thereddevils said:
v=u+at
This gives you the vertical component of the velocity, not the magnitude. What's the horizontal component? Use the components to find the angle.
argh , the answer is just right in front of me and i missed it . Thank you Sir .
  • · Replies 20 ·
  • · Replies 30 ·
