Higher Dimension Integrals: Solving for n in Exponential Functions
The discussion revolves around calculating integrals involving exponential functions and polynomial terms, specifically focusing on the integrals I(n, α) = ∫₀^∞ e^{-αx²} xⁿ dx and I(n) = ∫₀^∞ e^{-x} xⁿ dx. Participants are tasked with evaluating these integrals for whole integers and half-integers up to n=5.
  • Participants discuss using polar coordinates and integration by parts to evaluate the integrals. There are attempts to calculate specific cases, such as I(0, α) and I(1, α), with mixed results. Some participants express confusion over the integration process and the application of limits.
There is ongoing exploration of the integrals, with some participants successfully calculating I(0, α) but struggling with higher values of n. Questions about the correctness of results and the proper application of integration techniques are prevalent. Some guidance has been offered regarding the order of operations in integration by parts.
Participants note discrepancies in results and the need for careful consideration of limits and assumptions in the integrals. There is mention of a factor of 1/2 that arises from the properties of the integrand, which is under discussion but not fully resolved.
substance90
Calculate the following integrals:
(a) [tex]I(n,\alpha) = \int_{0}^{\infty} e^{-\alpha x^2}x^n dx[/tex] for n whole integers and [tex]n \ge 0[/tex]
Calculate all results till n=5.
Tip: First calculate [tex]I^2(0,\alpha)[/tex] and [tex]I(1,\alpha)[/tex] and then use this to calculate n>1.
(b) [tex]I(n)=\int_{0}^{\infty} e^{-x}x^n dx[/tex] for n whole and half integer where [tex]n\ge -1/2[/tex]
Tip: Calculate I(n) using I(0) and I(-1/2).
(а) I managed to do the first part using polar coordinates and substitution [tex]I(0,\alpha) = \sqrt{\frac{\pi}{\alpha}}[/tex] but I keep getting 0 for [tex]n \ge 1[/tex]
For example with 1: [tex]I(1,\alpha) = \int_0^{\infty} e^{-\alpha x^2} x^1 dx = x \sqrt{\frac{\pi}{\alpha}} -\int_0^{\infty} \sqrt{\frac{\pi}{\alpha}} 2x dx = x^2 \sqrt{\frac{\pi}{\alpha}} - x^2 \sqrt{\frac{\pi}{\alpha}} = 0[/tex]
(b) The first part here is ok: [tex]I(0) = \int_0^{\infty} e^{-x} dx = -e^{-x}[/tex] but I tried a thousand times to do I(-1/2) and keep going in circle with integration by parts.
Any ideas would be greatly appreciated!
What happened to the exponential when you integrated by parts?
You can use the result from part (a) to solve (b), so figure out (a) first.
Well, we know from the first part that [tex]\int_{0}^{\infty} e^{-\alpha x^2} dx = \sqrt{\frac{\pi}{\alpha}}[/tex] or am I missing something?
You're doing things out of order. You can't plug the limits in until the end. Consider a simpler example:
[tex]\int_0^\infty xe^{-x}\,dx[/tex]
Let f=x and dg=e-x dx. Then df=dx and g=-e-x, and you should get
[tex]\int_0^\infty xe^{-x}\,dx = \left[-xe^{-x}\right]_0^\infty + \int_0^\infty e^{-x}\,dx[/tex]
But what you're doing is saying
[tex]g = \int_0^\infty dg = \left[-e^x\right]_0^\infty = 1[/tex]
so that
[tex]\int_0^\infty xe^{-x}\,dx = -x\cdot 1 + \int_0^\infty 1\,dx[/tex]
See the difference?
Anyway, if you attempt integration by parts properly, you're stuck trying to integrate exp(-ax2) without the limits, which you can't do. Instead, for the n=1 case, try the substitution u=-ax2.
Well, I did what you said and I got [tex]- \frac{1}{2}[/tex] by substitution in [tex]I(1,\alpha)= \int_0^{\infty} e^{-\alpha x^2} x^1 dx[/tex] but now I`m stuck on all the other expressions [tex]n \ge 2[/tex]
The Tip says to get solutions for [tex]I^2(0,\alpha)[/tex] and [tex]I(1,\alpha)[/tex] and use this information to solve the others to n=5 but I don`t see how this helps me any further.
Recheck your work. The integrand is positive over the interval of integration, so the integral should be positive. Also, the α is missing from the answer.
Now use integration by parts to find I(n,α) for n≥2.
I corrected it, there was a mistake in the substitution. So, now I have [tex]\scriptsize I(1,\alpha) = \frac{1}{2\alpha}[/tex]
I`m having real trouble with the integration by parts of I(n,a) for n>1, though.
If I choose [tex]\scriptsize u=x^2[/tex] and [tex]\scriptsize \dot{v} = e^{-\alpha x^2}[/tex] I`m stuck because I cannot integrate [tex]\scriptsize \dot{v}[/tex] without transformation to polar coordinates.
If I choose the other way around, I get stuck again because I just get x with a growing exponent in the integral.
Keep one power of x with the exponential so you can integrate it with a substitution.
I`m not sure I understand what you mean by that. I cannot get to [tex]\scriptsize x^1[/tex].
I tried integration by parts that way:
[tex]\int_0^{\infty} e^{- \alpha x^2} x^2 dx =[/tex]
[tex]= \biggl [\frac{x^3}{3} e^{- \alpha x^2} \biggr ]_0^{\infty} + \int_0^{\infty} 2 \alpha x e^{- \alpha x^2} \frac{x^3}{3} dx =[/tex]
Now, if I substitute [tex]u=-\alpha x^2[/tex] and [tex]dx=\frac{du}{-2 \alpha x}[/tex] I cannot manage to get rid of that nasty [tex]\scriptsize x^3[/tex].
In the end, whatever I try I just get [tex]\scriptsize - \frac{x^3}{3} + 0[/tex] from the integral.
What I'm saying is you have choices other than u=xn and dv=exp(-ax2)dx. You don't have to put all of the x's from the xn factor into u and just the exponential into dv.
That way I got an answer 1/2a for I(2,a), too. Could this possibly be right?
No, it's not right. You should find I(n+2) is proportional to I(n).
By the way, your answer for I(0,α) is missing a factor of 1/2.
I`ve got I(0,a) from my "Mathematical methods in physics" textbook, I thought it was supposed to be correct.
[PLAIN]http://img267.imageshack.us/img267/426/answer.jpg
Where do I get the 1/2 factor from?
The lower limit of the integral in the book is [itex]-\infty[/itex]. The lower limit on your integral is 0.
I see the logic of that but I still cannot mathematically derive this factor of 1/2...
The easy way to show this is to note that the integrand is an even function, so you'd have
[tex]\int_0^\infty e^{-\alpha x^2} dx = \frac{1}{2}\int_{-\infty}^\infty e^{-\alpha x^2} dx[/tex]
You could also follow the derivation in the book with slight modifications. Both the x and y integrals would go from 0 to ∞ instead of from -∞ to ∞. The region of integration would therefore be only the first quadrant rather than the entire xy plane, so when you change to polar coordinates, the angle φ would go from 0 to π/2 instead of 0 to 2π. The end result is a factor of 1/2 in the final answer.
Thank you for your time, this really helped. At least now I have a small part from the first part of the first problem. Too bad that there is no time to finish it, I have to submit the homework in 20 minutes.
I`ll still look further into that later today, although it will be too late for points from the homework.
