Solve Integration Proof: \nabla^2 p(x') on B(x,t) to S(x,t)
The discussion revolves around a proof involving the time derivative of an integral of the Laplacian of a function \( p(x') \) over a 3D ball \( B(x,t) \) and its surface \( S(x,t) \). The participants are exploring the application of the divergence theorem and the transition from volume to surface integrals in the context of spherical coordinates.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the necessity of the divergence theorem to relate the volume integral to the surface integral. There are attempts to express the volume element and surface element in spherical coordinates. Questions arise regarding the dependence of \( p(x') \) on the variables involved and the implications of changing the radius of the ball.
There is ongoing exploration of the problem with various interpretations being discussed. Some participants have provided insights into the notation and assumptions, while others are questioning the dependencies of the variables and the correct application of the divergence theorem. Guidance has been offered regarding the conversion to spherical coordinates and the implications of the radius being a function of time.
Participants note that the problem may be simpler than initially perceived, as indicated by the original text. There is also mention of the initial conditions of the wave equation related to \( p(x) \), which adds context to the discussion. The confusion regarding the relationship between the radius and time is acknowledged, as well as the need for careful handling of the integrals and their limits.
Mmmm
Show that
[tex]\frac{\partial}{\partial t} \int_{B(x,t)} \nabla^2 p(x') dx'=\int_{S(x,t)} \nabla^2 p(x') d\sigma_t[/tex]
[Hint: Introduce spherical coordinates.]
I thought the divergence thm would be necessary to get from the ball to the surface of the ball and so I will need to construct a unit normal to the surface
[tex]x'=x+t\alpha[/tex]
where x is the vector to the centre of the ball, t is the radius and [itex]\alpha[/itex] is the unit vector in the direction of the radius, so x' is the vector to the surface of the ball
that makes [itex]\alpha[/itex] the unit normal, so using the divergence thm,
[tex]\frac{\partial}{\partial t}\int_{B(x,t)}\nabla^2p(x')dx' =\frac{\partial}{\partial t}\int_{S(x,t)} \nabla p(x+t \alpha ). \alpha d\sigma_t[/tex]
this is where I get (more?) lost...
converting to spherical polars...
[tex]d \sigma_t = r^2 sin\phi d\theta d\phi[/tex]
so
[tex]= \frac{\partial}{\partial t}\int_{S(x,t)} \nabla p(x+t \alpha ). \alpha r^2 sin\phi d\theta d\phi[/tex]
and really... I'm stuck...
what is r in terms of t ? I must be going the wrong way here.
can you explain your notation in the OP... I'm guessing:
p(x') is a scalar function, is there anything else special about p?
B(x,t) is a 3D ball
S(x,t) is the closed surface of the ball
dx' = dV a volume element
what is [itex]d \sigma_t[/itex]?
Well, in the text before the question, p is part of the initial conditions of the wave equation but by the way the question was worded I thought that this was just a general identity.
In the text,
[tex]\nabla^2u(x,t)-u_{tt}(x,t)=0[/tex]
where [itex]u(x,0)=0[/itex] and [itex]u_t(x,0)=p(x)[/itex]
[itex]d \sigma_t[/itex] is the surface element of the ball with radius t.
Your other guesses are spot on...
Also, rather annoyingly, the text says "it is an easy exercise to compute the derivative on the left side of the equation - see problems" so maybe this is a much simpler thing than I am thinking...
ok, got you now... & i think i can explain why its so though... imagine changing the radius of the ball by dt, the addition to the volume integral will be the thin spherical shell multiplied by p(x) giving the integral on the right hand side.
Now we need to try & put into identities, so first start by assuming a ball at the origin to make thing easier, we can generalise later if need be
note you cannot just move the t derivative under the integral while the bound of the integral is also dependent on t.
now a couple of points on your attempts so far, not 100% where it will lead, buts let's have a try, the divergence theorem should be applied as follows:
[tex]\int_{B(x,t)}\nabla^2p(x')dx' =\int_{B(x,t)}\nabla \bullet (\nabla p(x')dx') <br /> =\int_{S(x,t)}\nabla p(x') \bullet \textbf{da}[/tex]
where [itex]\textbf{da}[/itex] is a unit area element pointing outward normal from the ball
also this should be an area element not an volume element?
in this wave equation isn't t time, so which is it?
Yes, t is time... so our ball is getting bigger!
I have seriously messed up the spherical polars bit as I was sort of half thinking we had a ball centered at O and so r would be constant (at a single moment of time).
As you can probably tell, I'm very confused.
Your divergence theorem bit is the same as mine right? I just split your .da into [itex].\alpha d\sigma_t[/itex]
if t is the radius of the ball consider converting the volume integral directly to spherical coordinates as such...
[tex] \frac{\partial}{\partial t} \int_{B(x,t)} \nabla^2 p(x') dx'<br /> = \frac{\partial}{\partial t} <br /> \int_0^t dr \int_0^{\pi} d \theta \int_0^{2 \pi} d \phi .r^2 .sin\theta. \nabla^2 p(x') [/tex]
ok if i understand correct r is a linear function of t, say [itex]r = \alpha t[/itex],
try this then...
[tex]\frac{\partial}{\partial t} \int_{B(x,t)} \nabla^2 p(x') dx'= \frac{\partial}{\partial t} \int_0^{\alpha t} dr \int_0^{\pi} d \theta \int_0^{2 \pi} d \phi .r^2 .sin\theta .\nabla^2 p(x')[/tex]
you should be able to do this derivative with a simple change of variable
not quite, you have to retain the dot product, as you don't know the direction of grad(p), that is unless p is spherically symmetric...
anyhow, looks like there is a better way to do it as per the last post ;)
updated above with the correct volume contirbution for the integrand r^2 sin(theta)
PS - sorry for the multi-multi-posts, but its shows if you can avoid confusion laying out the problem, it may make life easier ;)
try this then...
is
[tex] \frac{\partial}{\partial t} \int_0^{\alpha t} dr \int_0^{\pi} d \theta \int_0^{2 \pi} d \phi .r^2 .sin\phi .\nabla^2 p(x') [/tex]
the same as
[tex] \frac{\partial}{\partial t} \int_0^{\alpha t} \int_0^{\pi}\int_0^{2 \pi} r^2 sin\phi \nabla^2 p(x') d \phi d \theta dr[/tex]
if so, don't you have to change p(x') to polars too so that you can integrate it? isn't x' dependent on r, theta and phi?
Ahh... Having had a bit of time to mull it over, p is not dependent on t (or r), so integrating wrt r first
[tex] <br /> \frac{\partial}{\partial t} \int_0^ t \int_0^{\pi}\int_0^{2 \pi} r^2 sin\phi \nabla^2 p(x') d \phi d \theta dr<br /> [/tex]
[tex] <br /> =\frac{\partial}{\partial t} \int_0^{\pi}\int_0^{2 \pi} \frac{1}{3}t^3 sin\phi \nabla^2 p(x') d \phi d \theta<br /> [/tex]
[tex] <br /> = \int_0^{\pi}\int_0^{2 \pi} t^2 sin\phi \nabla^2 p(x') d \phi d \theta<br /> [/tex]
and then back to cartesian coords gives the result... wow, thanks lanedance...that's really helped, but this is for r between 0 and t though, ie ball centred at O. for a ball centred at x, though, I suppose it could range between [itex]\left| \textbf{x} \right| -t[/itex] and [itex]\left| \textbf{x} \right| +t[/itex] and for that it doesn't behave at all.
it should behave eaxctly the same, just use a variable change to shift to the centre of the ball before changing to spherical coords
ah, yes so a simple substitution X=x'-x will shift the ball to the origin. when x'=x X=0.
dx'=dX so there is no difference.
Thanks for your time Lanedance
no worries ;)
  • · Replies 24 ·
