| Thread Closed |
Propeller slipstream |
Share Thread | Thread Tools |
| Jun8-10, 11:46 AM | #1 |
Is the effect that the propeller slipstream (i.e the helix) hits the tailplane causing much instability quite significant such that if u are using a tractor propeller a single rudder wont work creating the need for two rudders away from the slipstream path??
| Jun8-10, 01:42 PM | #2 |
There is no easy answer to that question, as it depends on the design of the aircraft. The effect of the slipstream is to induce a sidewash factor that modifies the verticle fins angle of attack.
| Jun8-10, 11:09 PM | #3 |
Is there any way to actually find the path of the helix???....like using CFD.
| Jun8-10, 11:48 PM | #4 |
Sure, you can run CFD and then look at a plot of the streamlines. But that is going to be a huge under taking, and require a ton of processing power.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Propeller slipstream
| slipstream effect | Aerospace Engineering | 9 | ||
| propeller efficiency | Aerospace Engineering | 1 | ||
| How calculate propeller efficiency if I know propeller trust? | General Engineering | 47 | ||
| shaping a propeller . . . help! | Mechanical Engineering | 8 | ||
