Solving Improper Integral: \int_{-\infty}^{\infty} {xe^{-x^{2}}dx}
The problem involves evaluating the improper integral \(\int_{-\infty}^{\infty} {xe^{-x^{2}}dx}\), which is situated within the context of improper integrals and integration techniques.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the nature of the function \(xe^{-x^{2}}\), with some asserting it is even while others correct this to odd, prompting a reevaluation of the approach. Integration by parts is attempted, but participants express difficulty in resolving the integral. Substitution methods are suggested as potentially more effective.
The discussion is ongoing, with various methods being explored. Some participants have provided alternative perspectives on the function's properties, and there are indications of progress with substitution methods. However, there is no explicit consensus on the best approach yet.
There are indications of confusion regarding the classification of the integrand as even or odd, which affects the approach to solving the integral. Participants are also navigating the limitations of integration techniques available to them.
Lancelot59
This is the problem:
[tex]\int_{-\infty}^{\infty} {xe^{-x^{2}}dx}[/tex]
I noticed the function was even, so I then did this:
[tex]2\int_{0}^{\infty} {xe^{-x^{2}}dx}[/tex]
I attempted to do integration by parts:
[tex]u=e^{-x^{2}}, du=-2e^{-x^{2}}, dv=x, v=\frac{x^{2}}{2}[/tex]
which still left me with this at the end:
(I left out the bounds)
[tex]\frac{x^{2}}{2}(e^{-x^{2}} - \int_{}^{} {e^{-x^{2}}dx})[/tex]
and of course that integral can't be done. Doing parts the other way results with the same issue, and I don't see how a substitution could work. Thanks in advance for any help.
Why do you think x*e^(-x^2) is even?
The integrand is not an even function - it is odd. This should make the problem a lot easier.
That's not the best approach. An ordinary substitution is all that is required.
I see. I'll post back once I'm done with the work.
Bad logic. That's why. I thought about it more and it isn't.
It worked.
[tex]u=e^{-x^{2}}, du=-2e^{-x^{2}}dx \rightarrow \frac{du}{-2u}=xdx[/tex]
Then got here:
[tex]\lim_{t \rightarrow -\infty}\int_{t}^{0} {xe^{-x^{2}}dx} + \lim_{t \rightarrow \infty}\int_{0}^{t} {xe^{-x^{2}}dx}[/tex]
Substituted:
[tex]\lim_{t \rightarrow -\infty}\int_{x=t}^{x=0} {-\frac{du}{2u}u} + \lim_{t \rightarrow \infty}\int_{x=0}^{x=t} {-\frac{du}{2u}u}[/tex]
[tex]-\frac{1}{2}\lim_{t \rightarrow -\infty}\int_{x=t}^{x=0} {du} + -\frac{1}{2}\lim_{t \rightarrow \infty}\int_{x=0}^{x=t} {du}[/tex]
Then I just got u as the integral, did the rest and found that it converged on zero. Thanks for the help.
  • · Replies 47 ·
