Calculating Flowerpot Height | Freefall Problem Help
  • Thread starter Thread starter teknodude
    Freefall
The discussion centers on calculating the height a flowerpot reaches above a window based on its motion. The flowerpot was in view for 0.61 seconds, and the window height is 2.45 meters. The initial velocity was determined to be 7.00 m/s, leading to a calculated height of 0.049 meters above the window. A common error identified was misunderstanding the total time in view, which should be halved for accurate calculations.
  • Understanding of kinematic equations in physics
  • Familiarity with gravitational acceleration (g = 9.81 m/s²)
  • Ability to manipulate algebraic equations
  • Basic knowledge of projectile motion concepts
  • Review kinematic equations for projectile motion
  • Practice problems involving freefall and initial velocity calculations
  • Learn about the impact of total time in view on motion problems
  • Explore resources on common mistakes in physics problem-solving
Students studying physics, particularly those tackling kinematics and projectile motion problems, as well as educators looking for examples of common student misconceptions in these topics.
teknodude
A drowsy cat spots a flowerpot that sails first up and then down past an open window. The pot was in view for a total of 0.61 seconds, and the top-to-bottom height of the window is 2.45 meters. How high above the window top did the flowerpot go?
I first tried to calculate the initial velocity by assuming the initial position to be zero and the 2.45 for the max. Using formula y=-1/2gt^2 + v(t) +Yinitial
2.45 = -1/2g(0.61)^2 + V(0.61) o
intial velocity=7.00 m/s
velocity should equal zero, that's when the flowerpot reached its highest point. Then solving for time when the pots velocity is zero, will be give enough info to calculate the height above the window the pot traveled. Using equation v=-gt+vintial 0= -gt + 7.00 t= 0.714s
Plugging back into the first used equation
y= -4.9(0.714)^2 +7.00(0.714) y= 2.50m subtracting from 2.45m = 0.049m
So the flowerpot went 0.049m above the window?
I enter my homework answers on this site called webassign. My first answer was incorrect and another wrong answer will start deducting points...
I am really confused because my textbook had the same Homework problem, however the values were different. height was 2.00m, time= 0.50s. I did the same procedure as stated above on the problem in my text, but i could Not get close to the answer of 2.34m from the solution in the back of the book.
Welcome to PF!
Note that it gives total time in view. Each pass is only half that time.
Nothing wrong with your thinking, but you have the wrong time. Do it over.
The book's answer is correct. So you know that you are doing something wrong! Probably the same error. Redo the textbook problem and make sure you get it right before redoing your homework.
Thanks Doc Al, I overlooked the fact that the time given was total time. I redid the problem in the textbook and got 2.45m as my answer. :biggrin:
38K
  • · Replies 18 ·
