Confusion with curved space analogies
The discussion centers on the confusion surrounding analogies used to explain gravity as a curvature of space-time. Participants explore the implications of these analogies, particularly in relation to stationary objects in a curved space-time and the nature of their movement or lack thereof.
  • One participant expresses confusion about why a stationary mass on a curved surface would move, questioning the logic of using gravity to explain gravity.
  • Another participant suggests that the analogy of a curved plane is misleading and emphasizes that in curved space, geodesics are not straight lines, which may not accurately convey the concept of gravity.
  • A different analogy involving airplanes flying over the Earth is introduced to illustrate how paths can appear straight while leading to convergence, hinting at the complexities of curved space-time.
  • One participant reiterates the need to include the time dimension in explanations of gravitational attraction, indicating that the analogy of curved space alone is insufficient.
Participants do not reach a consensus on the effectiveness of the analogies used to explain gravity. There are multiple competing views regarding the clarity and accuracy of these analogies, and the discussion remains unresolved.
Some limitations in the analogies are noted, such as the failure to convey the role of time in the curvature of space-time and the potential for misunderstanding the nature of gravitational attraction for stationary objects.
DragonPetter
I've always been confused by the typical analogies I see when gravity as a space-time curvature is explained.
In 2-D it is usually a plane with field lines, and the surface of the plane is curved around an object. And so we are told a mass placed in this curvature will "fall" down the curve and that's how objects are moved in gravity. Its also given in the analogy of a funnel with a coin rolled down the funnel.
Then the more exact 3-D and 4-D models are given, but its still the idea that an object will "fall" along the curve towards the mass causing the curve.
My confusion is why do the objects move along the curvature? Say you took a stationary mass and placed it on the curved surface. Why would that mass want to move down the curve if its at rest? In the analogies, its actually gravity that is implied to move the object along the curve so they're using gravity to explain gravity which doesn't make sense.
So to sum it up, can someone answer or explain this question:
Take a stationary particle, of very low mass. Place it in the "curved" area of space-time around a large mass. What is making the particle accelerate on that curvature? Why isn't it happy staying in the spot its placed even though the spot might be curved in towards the larger mass?
These analogies are misleading sometimes. I'm actually not sure in every case what they are supposed to show but here's what I think they should show.
You see a deforme plane. Now draw a straight line on it (or at least, try to do so). The standard procedure is to lay an arrow on the plane and move it always in the direction it is pointing, without deliberately rotating it. You end up with a curved line, which is calles a geodesic. That's what you can learn, in curved space geodesics ("supposed straight lines") are curved. Nothing to do with something falling in the funnel, it'd work exactly the same if the funnel were bent upwards.
Don't take it too literal as explaining gravity. There is one aspect missing that these pictures can't convey: It's not space that is bent, it's spacetime. The combination of space and time.
Every point in space, like a planet or so, is represented by a line in spacetime (its "worldline"). For example the world line of a particle at rest goes from past to furture, but not in a spatial direction. Like a straight line upwards in a spacetime diagram.
in curved spacetime, its worldline is curved into the space direction, which means that the particle is beginning to change its position due to gravity.
Consider two airplanes flying over the surface of the Earth. They start out at the equator, and fly northward with the same speed, along different longitude lines. Each plane flies a straight path, as far as it "knows," and continues to steer in the same direction. Nevertheless, as they go further north, they approach other, and collide at the North Pole.
The analogy you describe is one of curved space, and in fact it doesn't explain gravitational attraction of objects at rest in space. You need to include the time dimension to explain that:
http://www.relativitet.se/spacetime1.html
http://www.physics.ucla.edu/demoweb..._and_general_relativity/curved_spacetime.html
  • · Replies 37 ·
  • · Replies 27 ·
  • · Replies 22 ·
  • · Replies 30 ·
  • · Replies 17 ·
  • · Replies 29 ·
