Colliding Particles using energy
  • Thread starter Thread starter seto6
    Energy Particles
The problem involves the interaction between an alpha particle and a proton, specifically focusing on their distance of closest approach when both are moving towards each other at a fraction of the speed of light. The context is rooted in nuclear physics and conservation laws.
  • The original poster attempts to apply conservation of energy to find the distance of closest approach but questions their assumption that the final velocity is zero at that point. Other participants suggest reconsidering the hint about conserved quantities.
The discussion is ongoing, with participants exploring different interpretations of the problem and questioning the assumptions made by the original poster. Guidance has been offered regarding the use of conservation laws, but no consensus has been reached.
The original poster is revising for a mid-term and is working from a previous assignment. There is an emphasis on understanding the problem rather than simply solving it, as indicated by the hints provided in the discussion.
seto6
this question is from my previous assignment which was due 2 weeks back. just revising for mid-term not sure how to solve it. if someone explains it thoroughly it would be grate
An alpha particle is a nucleus of Helium. It has twice the charge and four times the mass of the proton.
A proton and an alpha particle headed directly toward each other, had each initial speed of 3.9×10−3 c when they were far away.
Here, as is customary when describing processes involving nuclear targets, the speed is expressed as a fraction of c, the speed of light.
What is the distance of closest approach between the proton and the alpha particle?
Hint: There are two conserved quantities. Make use of both.
U=Eqd or KqQ/r
K=1/2*(mv^2)
.5m(v_i)^2 + Eq(d_i)= .5m(v_f)^2 + Eq(d_f)
where (V_f)=0 then i solved for (d_f)
and got the 1.87*10^-27 but the answer should be d_f=1.3*10^-13
could some 1 explain this to me and the reasoning! please
You are assuming that V_f = 0. Make use of the hint that you were given.
Why don't you make an attempt using the hints I just gave?
v_f is the final velocity , at minimum distance it can reach it will be zero.no?
No it won't. Use the hint that the problem gave you! What else is conserved besides energy?
  • · Replies 54 ·
12K
  • · Replies 20 ·
14K
