Why is AC Power Transmission More Efficient Than DC for Long Distances?
The discussion centers around the efficiency of AC power transmission compared to DC for long distances, exploring reasons for the perceived superiority of AC, including technical aspects related to voltage, current, and transformer use. Participants also examine historical context and practical considerations in power transmission systems.
  • Some participants suggest that increasing voltage in AC transmission reduces current, leading to less energy loss due to resistance in wires.
  • Others clarify that while the concept of electrons "scraping" against wire sides is not accurate, the overall reasoning about reduced energy loss is correct.
  • One participant explains that AC allows for the use of transformers to significantly increase voltage, improving efficiency in power transmission compared to DC.
  • Another participant argues that AC is not inherently superior to DC, citing cost and practical challenges associated with high-voltage DC transmission.
  • Some participants note advantages of DC, such as reduced electric fields and simpler design requirements for insulation and switches.
  • Concerns are raised about the complexity and cost of integrating DC systems for consumer-generated power back into the grid.
  • Participants discuss the historical context of AC and DC systems, noting that early limitations in DC technology influenced the choice of AC for power transmission.
  • One participant highlights the advantages of DC in international links and reduced reactance losses for certain cable types.
  • There is mention of the transformer as a critical component in electrical engineering, drawing parallels to mechanical engineering concepts.
Participants express multiple competing views regarding the efficiency and practicality of AC versus DC transmission, with no consensus reached on which is superior. The discussion remains unresolved with various technical arguments presented.
Limitations include the dependence on historical context for technology choices, assumptions about cost implications, and unresolved technical details regarding efficiency comparisons.
Tregg Smith
Why is it that AC is superior to DC in long distance power transmisson. I was thinking it has something to do with the resistance of copper wire but if this is the reason then why is that? Or, why is copper loss not a factor with AC current? Thank you!
Welcome to the PF, Tregg. :smile:
https://www.physicsforums.com/showthread.php?t=410588
It's because by increasing the voltage, you're decreasing the current in the wires, which means the volume of electrons scraping against the side of the wire also decreases, so less energy is lost over long distances.
The electrons don't really "scrape along the side of the wires", but the rest of what you posted is correct.
A wire transmission line will have some fixed maximum current rating and, at that current, it will drop a certain voltage.
This applies equally to AC or DC.
Suppose this voltage drop is 50 volts and the current was 1000 amps.
If the voltage entering the line is 120 volts, the output will be 70 volts at 1000 amps or 70 KW.
The input was 120 volts at 1000 amps, so the input power was 120 KW.
This is a very poor efficiency of 58 % but it also provides an output of only 70 volts at that load. And, the line voltage would be very dependent on load.
If the supply was DC, there is only one thing you could do to deliver 120 volts to the consumer. You would have to feed 170 volts into the line and keep adjusting this, depending on the load. If you got it wrong, all the light bulbs and most other equipment could be destroyed by getting too much voltage.
If the supply was AC, you could use a transformer to increase the supply voltage to 3300 volts. Now the input power is 3300 volts at 1000 amps or 3300000 watts and the output power is (3300 - 50) * 1000 or 3250000 watts. This is an efficiency of 98.5% and 46 times as much power out as before.
You still have 3250 volts to deal with, but a transformer will convert this back to 120 volts again.
These transformers are expensive but a negligible cost compared with the cost of the transmission lines. Using AC instead of DC gives you the opportunity to do this
Skin effect is not a factor at 50 Hz or 60 Hz. The skin depth at 60 Hz is 0.3 inches so there is no effect on conductors of less than 0.6 inches thickness.
AC is technically not superior to DC transmission. The reason we in the US have AC lines is the cost of DC line plus other benefit like simple 2 way transformers. In general the skin effect is minimal at 50 or 60Hz. The high voltage transmission lines can range from 765KV to 138KV after the substations it can be from 26KV to 4KV. These high voltage levels are difficult to generate as a DC voltage. Once they are up in the KV range they would then need to be switched down to a user level of 120V or 240V.
Back when the transmission lines where first put up there was either no way or no cheap way of doing DC at those high voltages. The advantage of going with DC is that you do not have the electric fields that the AC power lines generate and less talk from the lines.
The main advantage of AC power lines is the cost of going from high voltage to low and back from low to high.
2nd advantage is everything is naturally isolated.
3rd more recent advantage is that when the consumer wants to co-generate or have a micro generator they can very easily send that power back onto the grid. In a DC system there would need to be a switcher capable of going from 240 / 220 back to something like 4KV in the best case. The power companies would not want to incur that kind of cost just because someday someone may want to send power back out on the grid.
L
The transformer is a brilliant concept in electrical engineering - analogous to the lever in mechanical engineering. We couldn't do without either of them.
yes they sure are in fact did you know that the analysis of a 3 phase induction motor can be though of as a transformer with 2 airgaps and a shorted secondary?
L
Other advantages of DC are that you don't have to have the grids in-phase at each end so useful for international links.
You only have to design insulation and switches for the max DC voltage not the peak AC (which is 40% more than the RMS voltage)
And you don't have large reactance losses for buried or underwater cables.
But, as you say, even today it's much cheaper to step up/down high power AC than DC
Yes, as you say, I suppose if you consider the sea water as a secondary it would kind of "short" things out so to speak. L
L
I could believe anything about
1. Induction motors
and
2. Equivalent circuits
11K
