Can I Trim a Flat Flex Cable to Fit My A/C Unit?
  • Thread starter Thread starter cs003
    Cable Flat
This discussion focuses on the feasibility of trimming a flat flex cable to fit an A/C unit's control board. The user inquired about the pitch, defined as the center-to-center distance between contacts, and whether a 20-contact cable could be shortened by removing three contacts to match a 17-contact requirement. Experts confirmed that trimming is possible, provided the pitch remains consistent and the style of contacts is compatible. Resources such as Digi-Key were recommended for further information and purchasing options.
  • Understanding of flat flex cable specifications
  • Familiarity with electrical contact terminology
  • Knowledge of A/C unit control systems
  • Basic skills in cable modification techniques
  • Research flat flex cable specifications and compatibility
  • Learn about electrical contact styles and their implications
  • Explore resources on A/C unit wiring and control board configurations
  • Investigate purchasing options on Digi-Key for flat flex cables
Technicians, HVAC professionals, and DIY enthusiasts looking to modify or understand flat flex cables in A/C units.
cs003
Hi,
I apologize if this isn't the right forum for this. I tried to pick that which I felt was most appropriate.
My question is about 'flat flex cable'. Somebody I know recently purchased an A/C unit which uses a flat flex cable to connect the control board to the motor and such. They would like to mount the control board away from the unit, however that would require a longer cable. I am not familiar with this type of cable. I've done some research and the only thing I can tell is that the "pitch" is the spacing between contacts. But does this mean the gap between contactors, or the spacing from center to center of the contactor strips? Really all I know right now is that it has 17 contactors.
Basically if I know the pitch and let's say the only cable I can find has 20 contactors, but the same pitch is it safe to assume that they could simply trim 3 contactors off the ends in order for the cable to fit into the connector?
If anyone is familiar with this type of cable and can give me some info on it (like definitions of common terms like pitch, and other dimensions...) and even some good resources to find and buy this kind of cable I would greatly appreciate it.
Thanks in advance,
C
Computer science news on Phys.org
Pitch is the center to center distance.
Yes, you could probably trim down a 20 pin.
The style of contacts probably matters. Take a look at www.digikey.com and you could probably find diagrams there to help you out.
  • · Replies 36 ·
  • · Replies 61 ·
  • · Replies 25 ·
  • · Replies 33 ·
