Energy and Capacitors of metal spheres
The problem involves two uncharged metal spheres with a given capacitance and the task of calculating the work required to move a specific charge between them. The subject area relates to electrostatics and capacitor energy calculations.
  • The original poster attempts to determine the potential difference between the spheres and questions if they are on the right track. Some participants suggest using energy conservation principles to find the work needed, while others discuss the initial energy of the system and its implications.
Participants are exploring various interpretations of the problem, including the initial energy of the spheres and the relevance of the distance between them. Some guidance has been offered regarding energy equations, but no consensus has been reached on the specifics of the calculations.
There is a discussion about the initial conditions of the spheres being uncharged and how that affects the electric field and energy calculations. The distance between the spheres is also noted as potentially redundant, but its role in the problem remains unclear.
Mitchtwitchita
Two uncharged metal spheres, spaced 15.0 cm apart , have a capacitance of 24.0 pF. How much work would it take to move 12.0 nC of charge from one sphere to the other?
V = Q/[4(pi)eor]
(delta)K + (delta)U = 0 *I think
I'm not quite sure how to do this problem. I think I would first have to find out the potential difference between the spheres?
V = Q/[4(pi)eo*r]
=(12.0 x 10^-9)/[4(pi)(8.85 x 10^-12)(1.5 x 10^-1)
=719 V
Can somebody please tell me if I'm going in the right direction and, if not, could you please steer me in the right direction?
From the law of energy conservation, the work needed = the change in the energy of the capacitor. So all you need to find is the initial energy and the final energy.
So, U = Q^2/2C would be the equation to use?
Yes :)
Would the initial energy be 0 because they are originally uncharged?
What do you think? :)
I think so because the electric field depends on the charge of the spheres. Therefore, if there is no charge, there can't be any electric field.
There you go :)
Why is the distance given?
It's redundant.
Oh, ok. Thanks for your time.
  • · Replies 97 ·
