Calculating theoretical heating rate of sand
The discussion centers on calculating the theoretical heating rate of an inner steel cylinder surrounded by silica sand and air within a larger steel cylinder. The outer cylinder has a volume of 6095.9 cc, while the inner cylinder's volume is 395.3 cc, with walls measuring 1 mm thick. Key parameters include heat capacities of steel (500 J/kg C), sand (733 J/kg C), and air (1040 J/kg C), along with thermal conductivities of steel (19 W/m C), sand (1.3 W/m C), and air (0.024 W/m C). The heating process begins at 30°C and increases at a rate of 5°C per minute until reaching 500°C, with the primary challenge being to determine the time required for the internal cylinder to achieve 500°C.
  • Understanding of heat conduction principles in cylindrical geometries
  • Familiarity with thermal conductivity and heat capacity concepts
  • Basic knowledge of thermodynamics and partial differential equations (PDEs)
  • Experience with transient heat conduction equations
  • Study the Heat Conduction in a Cylinder equations for transient heat transfer
  • Research methods for calculating heat transfer in multi-phase systems
  • Learn about numerical methods for solving PDEs related to heat conduction
  • Explore thermal resistance concepts in composite materials
Engineers, researchers, and students involved in thermal analysis, reactor design, or materials science who are looking to understand heat transfer dynamics in cylindrical systems.
Bacat
I have a small steel cylinder centered inside a larger steel cylinder. The remaining space is filled with 60% silica sand and 40% air. I am heating the larger cylinder in a furnace at a known heating rate and I want to calculate the theoretical rate of heating of the internal cylinder. This is not homework- it's motivated by some reactor design research I am doing.
Some facts about the system:
Outer cylinder: volume = 6095.9 cc
Inner cylinder: volume = 395.3 cc
Walls of both cylinders are 1 mm thick
Calculated mass and volume of silica sand: 9063.9 g in 3420.36 cc
Calculated mass and volume of air: 2.75 g in 2280.24 cc
Heat capacities:
Steel: 500 J/kg C
Sand: 733 J/kg C
Air: 1040 J/Kg C
Thermal conductivities:
Steel: 19 W/m C
Sand: 1.3 W/m C
Air: 0.024 W/m C
Furnace: Begins at 30C and heats at 5C per minute until it reaches 500C. The real question is how long does it take for the internal cylinder to reach 500C?
I'm not sure which set of equations to use for solving this system. I've had basic thermodynamics courses and PDEs but don't remember how to calculate heat in a 3D body.
Should I be using Heat Conduction in a Cylinder to solve this or is there a better way? I think I need to work with the thermal conductivity instead of the specific heat capacity because I am interested in the amount of time it takes for the heat to conduct through the sand. Is that right?
[tex]Q = 2 \pi k \ell r_m \frac{T_1-T_2}{r_2-r_1}[/tex]
where [tex]r_m = \frac{r_2-r_1}{\ln r_2 - \ln r_1}[/tex]
Science news on Phys.org
It depends on the precise geometry (not shown), and involves solution of the transient heat conduction equation involving both thermal conductivity and heat capacity.
  • · Replies 27 ·
  • · Replies 26 ·
  • · Replies 19 ·
  • · Replies 25 ·
