Why isn't Beryllium a noble gas?
  • Context: Undergrad
  • Thread starter Thread starter a2009
    Gas
The discussion revolves around the question of why Beryllium is not classified as a noble gas, exploring the criteria for full electronic shells and the significance of different subshells in determining an element's inertness. Participants delve into concepts of electron configuration, quantum numbers, and the stability associated with filled subshells, with a focus on theoretical and conceptual aspects.
  • One participant questions how the fullness of angular momentum subshells relates to Beryllium's classification, noting its 1S2 2S2 configuration.
  • Another participant argues that the second electron shell must have both 2s and 2p orbitals filled to qualify as a noble gas, citing Neon as an example.
  • A participant raises confusion regarding Argon's status as a noble gas, questioning the relationship between quantum numbers and noble gas classification.
  • Discussion includes the complexity of orbital filling and the significance of outer valence electron shells in determining noble gas behavior.
  • Participants explore the energy differences between filled s and p subshells, suggesting that a filled p-shell is crucial for inertness.
  • Some participants mention Madelung's rule and its implications for the ordering of subshells based on energy levels.
  • There is a discussion about the stability of noble gases and how filled orbitals minimize exchange energy, with references to quantum mechanical effects influencing stability.
  • One participant notes that Beryllium's behavior in forming compounds challenges traditional models, indicating its unique properties.
Participants express various viewpoints on the criteria for noble gas classification, with no consensus reached on the specific role of subshell filling and energy levels. The discussion remains unresolved regarding the implications of these factors for Beryllium and other elements.
Participants highlight the complexity of electron configurations and the influence of quantum mechanics on stability and reactivity, indicating that assumptions about energy levels and stability may not apply uniformly across different elements.
a2009
Hello All,
I'm a physics major and trying to figure out how "full" electronic shells are determined. It really reduces to the question why isn't Beryllium a noble gas?
If an angular momentum subshells are what matters then the shells are:
[tex]1S^2 2S^2[/tex].
Clearly the [tex]2S[/tex] subshell is full, yet this isn't considered a noble gas.
Why??
Thanks a lot for any help.
It's not the subshells that matter. The second electron shell consists of both the 2s and 2p orbitals. When both of those are full you have the noble gas Neon.
i.e., the important thing is that all states of the same quantum number [itex]n[/itex] are filled. In Beryllium the n=2, l = 1 states are not filled.
Thanks for the reply!
However, if the quantum number n is all that matters, how can Argon be a noble gas??
Z(Argon)=18
but 2*1^2 + 2*2^2 + 2*3^2 = 28.
What I mean is, based on n, the order of noble gasses should be
He,Ne,Ni...
What is called a "shell"? It's evidently not angular momentum, and not energy...
Ok, I guess it's slightly more complicated than I led on/I made a mistake. It's when the outer shell of valence electrons is full that matters. The order in which the orbitals are filled is not strictly in order of increasing quantum number n. For instance, the d orbitals for a given n tend to get filled after the n+1 s orbitals. I guess it ends up that when the p orbitals (the outer shell) are fully filled you get a noble gas (for Ne to Rn - after that relativistic effects apparently screw things up so a hypothetical element that appears under Rn on the periodic table isn't expected to be a noble gas).
See this wikipedia page for more information: http://en.wikipedia.org/wiki/Electron_configuration
The filling of orbitals can get tricky (e.g., Co and Cu seem like they have their electron configurations mixed up based on the order of the periodic table)
Thanks again for the replies. That seems like a pretty simple rule.
Is there any kind of physical intuition behind this? Naively, one would expect that when s subshells (spherically symmetric) are filled that would fill a 'shell'.
Why of all the subshells is p the significant one?
I would say that's because energy levels of s & p are usually not very different.
It is energy, it's just not all of it.
Every filled sub-shell is spherically symmetric, and every filled subshell is relatively stable. (Leading to why copper is 4s1 3d10 rather than 4s2 3d9.
That's a throwback to the original question.
If all subshells are spherically symmetric and stable, what makes p a special subshell, that when it gets filled the element is inert?
Not p, p & s.
Because a filled p-shell for a given n is so much lower in energy than the s-shell with n+1, whereas d and f shells for a given n end up in-between the s and p energies for n+1. Hence the structure of the periodic table. Put another way, they're ordered by n + l, and for two sub-shells with the same n + l, the one with the lower l comes first. This is called Madelung's rule.
A perhaps better way is to invoke MO theory, drawing an MO diagram will show the noble gases won't form stable compounds. And it will show that beryllium (for instance) should form compounds. This is of the essence here, because as soon as another atom comes into play, it changes everything about the relative ordering of the orbitals.
But - very notably in this context - it also predicts that Beryllium should not form a stable compound with itself. It was not until the 50's or 60's or so that it was shown that Beryllium does in fact form a stable (if reactive) dimer. And it's not some weakly-bound van-der-Waals interaction either, even if it's not a proper covalent bond. In fact, the Beryllium dimer bond can't really be characterized, because it cannot be described in terms of any of the simplified models chemists use. Or even using explicit quantum mechanics using the more approximate methods. It's quite an exceptional case.
Thanks!
So if I understand correctly, there's a big jump in energy between a full p shell and the next s shell.
Madelung's rule applies to ordering the subshells in terms of their energy for increasing atomic number (and increasing number of electrons). But the question here is more about proving that given a fixed number of electrons, is the material inert? (i.e. which subshell is the most important to fill to qualify as a noble gas).
An s subshell is significantly higher in energy than it's preceding p subshell. Therefore it might be possible to gain a lot of energy by shedding these electrons (being doubly ionized). In contrast dropping from a p shell would require six fold ionization.
Am I getting warmer?
Yes, I suppose that's the best I can come up with. Although the s shell is not necessarily always lower either. (Ar- has its last electron in the p shell, but K, with the same number of electrons, has it in the s shell, which illustrates well how tricky this stuff can be)
But filling a shell of a higher n is obviously quite a bit higher in energy, which one can tell from the fact that it almost never happens. O2- is everywhere, but F2- simply doesn't exist, even though the latter should be at least as stable - if you ignore the quantum mechanics involved. There's really just Xenon hexafluoride and a handful of other such exotic and unstable compounds where this occurs.
Yes. Well remember here that for isolated atoms in vacuum, the neutral species is always lower in energy. The "stability" of noble gas configurations is not in itself large enough to offset the energy required for ionization. So it's only once other atoms/molecules come into play that this effect becomes noticable. So for instance, when you put an alkali metal in water (a highly dielectric medium), you stabilize the charge and hence lower the ionization energy. Only then does it become energetically beneficial for an alkali metal to drop its outermost electron (or for a halogen to gain one) and go to the noble gas configuration.
One has to watch out here with thinking too much in pure electrostatic terms. Electrons don't behave at all either like classical point charges or like a semi-classical charge-distribution 'cloud'. The relative stabilities here are governed to a large extent by purely quantum-mechanical effects, like Pauli repulsion/exchange energy. A filled orbital is not only more stable due to spherical symmetry, but also due to the fact that it minimizes the exchange energy. But this is not the case for an s orbital, which has no exchange energy since it only contains one electron of each spin. So this is the reason why a filled shell is more stable, but a filled s-shell is not so much more stable. And so you have Al3+ but not Al+. (Easy theoretical rationalization: Take a peek at the Hartree-Fock equations and note the negative sign in front of the exchange operator)
You could make an argument also in terms of Pauling electronegativities and such, but I think that would be cheating, since those are based on ionization potentials/electron affinities to begin with.
  • · Replies 0 ·
